older MF
/ older MF #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Local to me there are 2 large MF's for sale. One is a 1100? listed by the seller ( a mf dealer, agco, farmtrac.. etc.. cub.. ) as 110 hp. There is also a 1150? down the road.. owner says 150 hp.
Both units are fairly compact and brute-ish looking.. not large like say a case or ford of the same hp.
Both are in the 7-9$ k range.
Any comments on these models? pro / con?
Soundguy
/ older MF #2
Never sold anything that large, but have worked on a 1150. Back in their "hay-day" these units sold fairly well. The 1150 we worked on seemed like a well thought out machine and sounds like the price is fair for something that large. Not an expert on these machines by any stretch of the imagination, just sharing my experience with them, or one of them anyway.
/ older MF #3
Soundguy,
Per TractorData.com (MF 1100) :
Massey Ferguson
1100
Manufactured: 1964 - 1972
Cost: (US Dollars) $7700 (1972)
Power:
Drawbar (HP): 85
PTO (HP): 94
Engine:
Fuel: diesel
Cylinders: 6
Displacement (ci): 354
Compression:
Rated RPMs:
Firing order:
Oil capacity (qts):
Manufacturer: Perkins
Transmission:
Forward: 12
Reverse:
Transmission:
Forward: 6
Reverse:
Capacity:
Fuel (Gal):
Cooling (Qt): 0
3-Point:
Category: II
Lift (lbs):
Power Take-off (PTO):
Type: live
Speeds (RPM): 540
Tires:
Front: 7.50-16
Rear: 15.5-38
Dimensions:
Weight (pounds): 11500
Wheelbase (inches):
Length (inches):
Width (inches):
Height (inches):
and TractorData.com (MF 1150)
Massey Ferguson
1150
Manufactured: 1970 - 1972
Cost: (US Dollars) $14000 (1972)
Power:
Drawbar (HP): 120
PTO (HP): 136
Engine:
Fuel: diesel
Cylinders: 8
Displacement (ci): 511
Compression:
Rated RPMs:
Firing order:
Oil capacity (qts):
Transmission:
Forward: 12
Reverse: 4
Capacity:
Fuel (Gal):
Cooling (Qt): 0
3-Point:
Category: II
Lift (lbs):
Type: independent
Speeds (RPM): 540,1000
Hydraulics:
Type:
Capacity (gal):
Flow (gpm): 20
Outlets:
Tires:
Front: 11.00-16
Rear: 18.4-38
Dimensions:
Weight (pounds): 13600
Wheelbase (inches):
Length (inches):
Width (inches):
Height (inches):
I don't know these tractors but found the data on this site to be accurate for my MF 253.
Hope this helps.
/ older MF #4
Price wise I cant help you but we ran a 1100 for about 5 years this is a stout ,strong tractor with alot of options that were ahead of there time. We used it for working ground making hay and bush hogging.
The only reason we traded it was too get a tractor that was easier to haul .
