Oil & Fuel old water pump
/ old water pump #1
razafas
Romania
UTB u445/m650
This is a bit off topic since is not about a tractor, but a water pump ; A 16 hp. 2 stroke gasoline engine from 1987 (never used, and dirt cheap). The thing is that i don't know how gasoline used to be 29 years ago, i know it used to be lower octane and more viscus; and in order to somewhat mimic this i added more 2T mixing oil (50mL per 1 liter), but the engine seams to be running hotter (burned thru the head gasket seal) and the spark plug gets dirty fast.
Anyone have solution for this ?
/ old water pump #2
Not an expert on gasoline from the Ceaușescu era, but I think you would have been better off just running regular old gasoline and not second guessing things.
/ old water pump #3
You are WAY overthinking this. Just put some 87 in it. My tractors from the 50's does not care. My 2c leafblower form 91 does not care and my 2c snowmobile from 72 does not care. Adding oil beyond 50/1is just going to foul the plugs like you are seeing. Running hot may be a carb or cooling issue. (plugged fins)
/ old water pump #4
That's a 20:1 mixture. That should be fine in an '87 (or any 2 stroke for that matter, jetted accordingly). The owner's manual recommendations should help a bit.
Think about this: when you put more oil in the fuel you are increasing the oil/fuel ratio but decreasing the fuel/air ratio. This leans the mixture and generally leads to hotter running.
What do you mean by "burned thru the head gasket seal"? Sounds like a wreck to me...
/ old water pump #6
2 stroke = no valves or valve seats to wear out ... so leaded or non leaded is fine...
just follow the specs for 2 stroke oil for the engine ....
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2005 Polaris Sportsman 700 EFI (A66408)
2005 Polaris...
