Old Victor Torch
/ Old Victor Torch #31
coxhaus I don’t recall what torch you have. Used torch tips (Victor and otherwise)are available on eBay.
If your torch IS Victor, I would imagine new Victor clones would be fine (and cheap). yomax4 will correct me if I am incorrect.
Getting a set to play around with would be fun.
/ Old Victor Torch #32
Someone on Welding Web posted this pic today. Itç—´ a fixture for holding a Victor regulator when dismantling. View attachment 646810
It is mounted on a piece of angle iron so that it can be held in a vise.
The actual "HEX" part on back of regulatory body (if there) is for holding body, a custom fixture is just a extra luxury....
Dale
/ Old Victor Torch #33
coxhaus I don稚 recall what torch you have. Used torch tips (Victor and otherwise)are available on eBay.
Yea maybe. I think I can now MIG weld anything I would gas weld. I can see no reason to gas weld anything. I still braze stuff with gas. Do you still gas weld?
I still remember using a coat hanger in a pinch when I ran out of welding rod. It seems like yesterday but it was many many years ago.
I guess I should say I probably have not brazed in the last 15 years because I don't think I any tips. I still have the flux stuff you dip the brazing rod in. I saw it the other day.
/ Old Victor Torch #34
I gas welded only once since high school. I think it was for a large truck exhaust pipe repair. I didn’t have a mig back then. I have tips and I keep thinking it would be a fun thing to do but that’s about as far as it gets.
I braze occasionally and use the cutting torch for heating and really heavy awkward cuts.
/ Old Victor Torch #35
There are some cool gas brazing rods out there. I like Nickel Silver for Art work and cast repair. It has a better expand and contract ratio than brass rod. In theory the Gas welders make great Tig welders. Didn't really apply to me though
/ Old Victor Torch
I finally got around to checking the old Victor torch setup out. I got that little Victor publication as a guide, very helpful. Everything works fine. I did replace the hoses, the old ones were pretty ratty. But regulators, valves, o-rings, all ok.
I cannot find any information on dating the serial numbers but it is at least 30 years old.
/ Old Victor Torch #37
They didn't change much in 30 years. only addition was built in flash arrestors and check valves. The new version isn't nearly as popular. If you know anyone with a liquid cooled plasma table they likely have a bunch of little tubs of oxygen safe grease for their torch head o-rings. ( it comes with every o-ring order) The stuff is great and makes o-rings last nearly forever.
Cat CB24B (A60462)
Cat CB24B (A60462)
iDrive TDS-2010H...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2013 Ram 1500 Crew Cab Pickup Truck (A59230)
2013 Ram 1500 Crew...
2016 FREIGHTLINER CASCADIA (A60736)
2016 FREIGHTLINER...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
