Old Victor Torch
/ Old Victor Torch #22
Being a long time ex Thermadyne Victor guy I can tell you this. Victor was always made in Denton TX. They needed a low cost line to compete with the Chinese knock offs so they came up with a China torch 1st called Medalist and later Cut Skill and back to Medalist. I think all of the supposedly Actual Victor torches are made in Hermosillo MX. along with the Edge Regs and the low cost is still China. New Victor torches are a shell of what the ones were even from 5 years ago. Harris Torches, Owned by Lincoln were made in Ireland for most of their life and about 8 years ago they switched to Poland due to ( I am told) work ethic. The Harris Regs are still made in Gainsville GA. I used to work there too. Smith was made for a long time in Plymouth MN. Then moved to Watertown S.D. due to ( I am told ) Taxes. They did well there until the 2008 crash and they restructured by bringing in the parts ( torches ) and assembling in Watertown. Then things changed again a few years back when they started sourcing regulator parts abroad and assembling in USA which meant Appleton WI. There is talk of the Smith Watertown plant closing this year. Sad how all this happened with everyone. When I was at Victor we always joked with our Smith friends ( we are all friends ) that we would buy a Smith Torch as soon as the Chinese copy one. Too expensive to copy until now. American Torch Tip co. in Florida is bringing in a Smith knockoff and people are buying it. It's actually half Smith and half Victor if you look close but it's Silver so it sells. So not much in the welding world is USA anymore. Miller boxes have said "Assembled" in USA for 5-6 years. It seems that now the hobby guys buy the $99.00 import Victor style and throw it away when the $30.00 hose needs to be replaced and buy a new one.
/ Old Victor Torch #23
Here are my old Victor regulators. I had them rebuilt a while back. Every time they rebuild them they look like new when you get them back.
I need to buy new hose. Should I buy the T version or does it matter? I think they have 3 versions of the hose, the regulator version, the R version and now the T version.
Oh, Terry I can not see your attachments.
yomax4, thanks for the Victor history. I knew there were changes but I could not remember.
/ Old Victor Torch
I found a copy of that Victor pamphlet on Abebooks and ordered it too. Looks like I have plenty of time for reading the next several weeks.
/ Old Victor Torch #26
Thanks coxhaus. I redid my post. I have no idea why this happens.
Should be able to see pics now. Thanks!
BTW Glad to see other torch/regulator repair outfits do nice work like the guy that fixes mine
/ Old Victor Torch #27
Those Victor 450's are really not that old as far as genuine Victor regs go. Getting harder to find since Victor went to the Edge regs.
/ Old Victor Torch #28
Which ones were the genuine victor regs?
The first regs I had back in the probably late 70s were Harris and then I sold them to buy Victor Texas made regs.
Maybe I did swap instead rebuild many years ago. Nothing comes to mind though. How old are the 450s?
/ Old Victor Torch #29
The 450's in your pic I would say are from the early to mid 2000's judging by the gauges and the newer style safety but the reg bodies didn't change much from the mid 80's on so someone could have put the newer style gauges on older regs. Fact is there really isn't much inside the regulators. You can spin the bonnet off and have a look. The 450's used a stainless steel diaphragm where lessor regs used rubber. This made them take pressure blast better without popping the diaphragm and they would handle condensation and cold gas better. ( other brands have SS as well on higher end regs). Other than the diaphragm there is a coil spring and needle and seat that's it.
/ Old Victor Torch #30
My dad was the gas welder. He could run a puddle really well with gas. So we had a understanding if it had to be gas welded then my dad would do it and if it needed to be arc welded I did it. There was no cheap MIG back then. You either gas welded or stick welded. Thin stuff we gas welded and thick stuff we stick welded. I guess it is possible he changed something while it was at his house. I can't remember it was too long ago. I some how did not end up with any of the old gas welding tips when my dad passed away 15 years ago.
Thanks yomax4 for all your knowledge on the old Victor stuff.
/ Old Victor Torch #31
coxhaus I don’t recall what torch you have. Used torch tips (Victor and otherwise)are available on eBay.
If your torch IS Victor, I would imagine new Victor clones would be fine (and cheap). yomax4 will correct me if I am incorrect.
Getting a set to play around with would be fun.
/ Old Victor Torch #32
Someone on Welding Web posted this pic today. Itç—´ a fixture for holding a Victor regulator when dismantling. View attachment 646810
It is mounted on a piece of angle iron so that it can be held in a vise.
The actual "HEX" part on back of regulatory body (if there) is for holding body, a custom fixture is just a extra luxury....
Dale
/ Old Victor Torch #33
coxhaus I don稚 recall what torch you have. Used torch tips (Victor and otherwise)are available on eBay.
Yea maybe. I think I can now MIG weld anything I would gas weld. I can see no reason to gas weld anything. I still braze stuff with gas. Do you still gas weld?
I still remember using a coat hanger in a pinch when I ran out of welding rod. It seems like yesterday but it was many many years ago.
I guess I should say I probably have not brazed in the last 15 years because I don't think I any tips. I still have the flux stuff you dip the brazing rod in. I saw it the other day.
/ Old Victor Torch #34
I gas welded only once since high school. I think it was for a large truck exhaust pipe repair. I didn’t have a mig back then. I have tips and I keep thinking it would be a fun thing to do but that’s about as far as it gets.
I braze occasionally and use the cutting torch for heating and really heavy awkward cuts.
/ Old Victor Torch #35
There are some cool gas brazing rods out there. I like Nickel Silver for Art work and cast repair. It has a better expand and contract ratio than brass rod. In theory the Gas welders make great Tig welders. Didn't really apply to me though
/ Old Victor Torch
I finally got around to checking the old Victor torch setup out. I got that little Victor publication as a guide, very helpful. Everything works fine. I did replace the hoses, the old ones were pretty ratty. But regulators, valves, o-rings, all ok.
I cannot find any information on dating the serial numbers but it is at least 30 years old.
/ Old Victor Torch #37
They didn't change much in 30 years. only addition was built in flash arrestors and check valves. The new version isn't nearly as popular. If you know anyone with a liquid cooled plasma table they likely have a bunch of little tubs of oxygen safe grease for their torch head o-rings. ( it comes with every o-ring order) The stuff is great and makes o-rings last nearly forever.
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
(UNUSED) MAIN MAK PORTABLE ALLEY WAY FOR CATTLE (A64278)
(UNUSED) MAIN MAK...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
UNUSED SDLANCH 14' BI-PARTING WROUGHT IRON GATE (A65055)
UNUSED SDLANCH 14'...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
