Old Barn to shop conversion
/ Old Barn to shop conversion #1
cny
Central NY
Kubota, B7800 HST
I am in the process of building an attached garage and a small addition to my house and I will be tearing down an old garage/shop (grey) behind the house and converting the lower portion of my barn (red) into a shop.
I am told that the new attached garage will be used for cars and motorcycles only!
The old grey garage is not only an eyesore, but is directly between my deck/patio and a 1/2 acre pond I dug a few years ago ...so it has to go.
The front section of the exisitng barn is 16' deep x 40' wide. 1/2 concrete and 1/2 dirt floor. It sits on a 8" block wall.
I would like to increase the depth to make it more usable ...probably 26-32' deep
I think I will use a mono truss spaced every 6-7 feet with a metal roof.
Not sure what I should do with the existing foundation/floor and walls. I have to at least remove the front wall, extend the side block walls and pour the 2nd half of the concrete floor.
I was thinking the easiset thing may be to remove everything - walls, roof, foundation, windows, doors, & concrete floor and rebuilding it as a pole barn wihout a foundation.
I would have to set my posts at approximately 48" deep to get below the frost line - alot easier than building a poured footing and laying eight+/- rows of block as I did for the addition.
What do you folks think? traditional stick built or pole barn style?
The old grey garage is currently blocking this view
...so it has to go
/ Old Barn to shop conversion #3
pole barn style
alows you to keep inital cost down while figure out what sections of it you want to "shop-itize" later.
8' OC mono trusses (mono sissors) would be easy. require ~3-4' of depth for 32' or so span with NY loading....
/ Old Barn to shop conversion #4
It just breaks my heart to see an old barn go down.
Is there any way on earth you could restore it. If you took a serious look at the numbers, it may work out best for you (and the building).
I will post pics of my current project: The total restoration of a large 1906 barn-one of the few of its kind in Oklahoma.
/ Old Barn to shop conversion #5
Not much of what you asked for, but I have a CST laser just like that one, also I don't like the view of the dogs butt before the pond either LOL.
I think I would do a pole barn just for the ease of construction, but it looks from the pics like you can do the other just as well. Have fun!
The Barn is not going down - I am just going to rebuild the front section. The barn was built in 1888 and I am restoring it. It is in overall good condition. The main barn is 40 X 120 deep. The front section (milkhouse) was built in the 60's +/- but is only 16' deep. It is not deep enough to park my tractor or truck. I just want to make it deeper ...28-32'.
The grey building is a P.O.S. It was built in the early 70's - it has to go.
/ Old Barn to shop conversion #8
schmism knows what he's talking about, so I'd follow his advice.
I am curious why you're not using preasure treated wood for your sill plates in the new construction?
Eddie
/ Old Barn to shop conversion #9
Glad to see the old barn is staying, it looks very cool! Old barns rock, and you can't destroy the darn things...
/ Old Barn to shop conversion #10
cny - since you live in NY - I'm assuming you have looking into the NY State Grants for repairing and restoring historic barns... based on your posted date - you should easily qualify for money. God knows we pay enough here in President Hillary's state... :(
Eddie
Eddie,
There is a double sill plate. The bottom plate is pressure treated sitting on a sill sealer bolted to the block wall every 4' +/-. The wall sections that we are standing up are not P.T. ...should both bottom plates be treated??? I hope not the garage/addition are pretty much done.
I think pole barn style is the way I am going to go.
fishpick,
What do you mean by "posted date"?
I have applied for a grant 3 or 4 times. I never really heard a thing from the state other than "sorry, you were not selected this year".
I guess I should keep trying. My barn is on a town road and visible from two state highways and one county road. Maybe I should seek help in writing a grant.
/ Old Barn to shop conversion #13
cny said:
Eddie,
You only need preasure treated wood where it comes into contact with concrete. I've never run two sill plates, so it not something I thought of when I saw your pictures. I figured that you had to cut the 2x6's in length to get an 8 foot wall with your top and bottom plates anyway, so another inch and a half isn't anything.
The only concern with going pole barn style is getting the poles deep enough for your area. Drill them deep and you'll have a very solid building!!!
Eddie
/ Old Barn to shop conversion #14
cny said:
fishpick,
What I mean - and what the joke I made was based on, was SUPPOSED to read...
"posted state" - as in the state you are from... in your post... but I blew it...
if it helps - I laughed when I posted it...
