Oil leak?
/ Oil leak? #1
TractorStumped
1974 Gilson Twin 16hp
Recently took my tractor in for a repair for new rods and rings due to a rod busting. The engine is a twin 16 hp Briggs and Stratton. My question is when I took it in for the repair it did not leak one drop of oil but now the guy is telling me that the rod put a hole in the engine. If it put a hole in the engine wouldnt it have leaked when it happened and not after he worked on it? I am just wondering if the repair guy made it leak or what he is telling me is true? The pictures he sent me from his garage not mine.
/ Oil leak? #2
It very common for a broken rod to knock a hole in the engine block when it breaks.
/ Oil leak?
Thanks for the reply but don't you think it would have leaked before I took it to him? The rod did break at my house.
/ Oil leak? #4
If it has a hole in the block that certainly isnt his fault. However I would wonder why he would rebuild a engine the had a hole in it. Seems like he would have caught that.
/ Oil leak? #5
G'day if it has a hole in the block then why didn't he fix it while it was apart?
My guess is that if it a vertical shaft engine then he has damaged the crank seal putting it back together no biggy it happens to all of us occasionally he should offer to repair.
Jon
29 x 9.0 x 15 5 Lugs Tires (A61573)
29 x 9.0 x 15 5...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2025 Wolverine MSG-11-44W 44in Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
HI-PRO PTO PUMP (A64280)
HI-PRO PTO PUMP...
