Oil in radiator
/ Oil in radiator #1
akjohnston
I posted this in another forum before I seen this one. I will repost here and perhaps receive a quick reply. I have a 8N ford and I am getting oil in the radiator, I am not getting water in the oil, only oil in the radiator. What could be the cause. Thanks
/ Oil in radiator #2
2 things.. 1, could really be oil in the radiator due to a cracked block... I've seen that a *few* times.
OR
Could be a head gasket leak and be letting combustion by products into the radiator that will make an oily sheen, and then emulsify to what more or less looks like oil in the radiator.
If you are NOT getting water in the oil, and your oil level is NOT going down, then flush radiator and retorque head bolts when warm.. Try it for at least a few hours of running..preferable a few days.. DO monitor oil for loss of level.. or water. After some run time.. recheck the radiator. if you find more oily sheen, start tractor and let her run.. look for bubbles in the radiator after she is warm.. either way.. with bubbles.. or lots more oily sheen.. you need to pull the head and replace the head gasket. There are 2 types.. a metal impregnated one.. and a thicker fibre one ( garlok? ) I like the fiber ones.. they are more forgiving of minor surface defects. Both types are put on 'dry'.. though if you use the metal one.. you can spray some aluminum or copepr spray paint on it to help it seal in.
Once the HG is off.. look for obvious problems.. like blown out spots.. etc.
Alternately.. before you pull the head.. if you have a comp tester, you can run a comp check.. pull all plugs, fuel off, throttle wide open.. crank engine over.. 5 puffs minimum.. though it is also ok to let it puf til the gauge stops moving. Then do the test again , wet ( 1 tablespoon oil in the cyl.. compair wet/dry numbers. Also do this on a warmed engine.
Ford spec is 90psi minimum for a good engine.. you may see as high as 120-130 on rebuilds. Most people find that if you have 75 psi or above you are good to go for an older tractor. Even compression across the board is better than big differences. I'd rather have 85 85 85 85 than 120 90 130 100.. etc.. post back for more help if needed.
Resist the temptation to have the hed shaved.. there is not much more than .010 to shave off.. and it may have already been done inthe past.. you don't want to create clearance problems ( checked by laying head on block with no plugs or gasket and bump engine over to see if head bumps up.. )
new heads for N are cheap enough to replace rather than bugger up if they are warped past usage..
Soundguy
/ Oil in radiator #3
There is another way to check this out. Snap on, and the other tool truck guys sell a radiator combustion gas detection kit. The actual procedure may vary from mfr to mfr, but here's what you do: You take the glass vial with the metal filter in the bottom, and you place it in the top of the radiator in the cap hole, with the tractor running at operating temp. Then you fill the vial with the liquid provided, to the line on the vial. Wait the prescribed time, and if the fluid changes color, you know for sure that somehow combustion gases are getting into cooling system. This test is good for even minute leaks, that the older methods can't find, and the fluid is reusable(if you don't get a positive test). Good luck:rolleyes: :rolleyes:
/ Oil in radiator #4
The only problem with that test is that it is so sensitive that contamination already present in the cooling system would set it off even if the leak was already fixed (yesterday).. etc.... not to mention.. a head gasket is only about 10 bucks and if you have less than gargantuan hands.. you can do it without taking the hood off.. thus it is about a half hour job start to finish..
Soundguy
karcher pressure washer (A61567)
karcher pressure...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
