Oil filter for New Holland 2120
   / Oil filter for New Holland 2120 #11
Lots of info posted by guys that don't know what a 1995 2120 is. Or think if a filter screws on it's correct.
I know a 1452/1515 fit my 1920. It had a 1515 on it when I got it. Never owned a 2120, though I know they are in the same family, have never seen where its panels are.
Its been ? 12 years since I owned it.. Can't remember where / how it mounted
   / Oil filter for New Holland 2120 #12
Whole different deal than a 1920.
   / Oil filter for New Holland 2120 #13
I knew it was bigger, didn't know it wasn't like a 3000 to 4000 ( is.. Similar 3 cyl, etc ) except in a 4. Thanks for the correction
Was a complete different beast? Rear axle and all?
I miss my 1920
   / Oil filter for New Holland 2120 #14
I miss my 1920
2120 was its own animal except for its less common brother the 2WD economy model 3415. Bigger chassis than a 1920 it had 28" rear rubber and took a bigger loader 7109 / 7309. Optional hydraulic shuttle tranny.
1920 actually shared lots more with its little brother 1720.
   / Oil filter for New Holland 2120 #15
Ahh. That's what threw me off. I've seen a 1720, and thought they looked alike. Never had the chance to see a 2120. Did look at a 3010s one time that I loved. And a 4?50 (3?6?) can't remember. Beefy looking.. Liked it too.
These days my 7610s stays parked. Batwing folded.. Cows n horses eating my pastures, only small 2-4 ac mowing... Use an old loose as a 2bit sloppy hooker 950 with nf for that. ;)
   / Oil filter for New Holland 2120 #16
4630? Maybee been a while.. Think I was a 4630. :)
2120 engine oil filter is parallel to the crankshaft.
Yes it is. It either has a cover over it, or is a cartridge style.
Looking up a NH 2120 with the 2.3L 4 cyl.Shibaura I come up with different numbers for NAPA, Wix, Fram, and Purolator.
Wix lists a NH 2120 with 2.3L Shibaura as using a Wix 51348
NAPA lists a NH 2120 as using a NAPA 1348
OP, look up your 2120 on the Wix site then go to Fram to cross reference the Wix number.
Wix to Fram cross reference can be a Fram 3614,3614FP,7575, or 6016
Purolator cross shows a L10241
I tried cross refrencing the Wix number on Fram site didn't work. Wix called for two different filters, two different sizes for Shibaura engine. I just don't know where to get wix,locally, since I wante to do it this weekend.
NAPA lists Shibura engine, but two filters 1348 and 1349. I might get both. Pictures shows regular screw on cartridge. Not sure if it a generic picture.
On the side of the engine is a blue cylinder, that I assumed was the the filter. Makes me think cartridge or paper filter. As you probably guessed this is my first oil change. ***edit, going off memory, and maybe all wrong.
   / Oil filter for New Holland 2120 #20
Yes, the Wix site listed 2 filters but I ruled out the first one because its a tall filter and someone said a short filter is required. Both use 3/4 - 16 thread. Get one of the others. NAPA 1348 (short filter) is the same as the 51348 Wix. The NAPA 1349 is the tall filter.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55314)
Kuhns AE10 Small...
2011 GMC Sierra Ext Cab 4X4 Pickup Truck (A55852)
2011 GMC Sierra...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
