Oil filter for New Holland 2120
   / Oil filter for New Holland 2120 #1
Zerk
Wisconsin/UP
New Holland 2120
I have a 1995 Ford New Holland, diesel. Shibura. Looking for oil filter #. When I look it up Fram nothing for New Holland, and for Ford it calls it Ford diesel, not Shiburu.
The tractor doesn't live with me. I'd like to get a filter and go change it. I didn't look at filter last time I was there. I am not committed to Fram, they are just common.
I've only looked at Fleet Farm. I haven't tried Napa or Carquest.
Thanks for any help.
Thanks
   / Oil filter for New Holland 2120 #4
Fram PH8A, THE generic Ford Filter.
   / Oil filter for New Holland 2120 #5
I think FL1A might be the better one to say for ford.. since it' is motorcraft. :)
while we are kicking out 'will fit'
the napa 1515 or preferably, 1452 will hang on their too.
   / Oil filter for New Holland 2120 #6
Don't think the longer filters will work, the side panel is to close.
Ed
   / Oil filter for New Holland 2120 #7
Looking up a NH 2120 with the 2.3L 4 cyl.Shibaura I come up with different numbers for NAPA, Wix, Fram, and Purolator.
Wix lists a NH 2120 with 2.3L Shibaura as using a Wix 51348
NAPA lists a NH 2120 as using a NAPA 1348
OP, look up your 2120 on the Wix site then go to Fram to cross reference the Wix number.
Wix to Fram cross reference can be a Fram 3614,3614FP,7575, or 6016
Purolator cross shows a L10241
   / Oil filter for New Holland 2120 #10
Lots of info posted by guys that don't know what a 1995 2120 is. Or think if a filter screws on it's correct.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
