Oil filter for New Holland 2120
   / Oil filter for New Holland 2120 #11
Lots of info posted by guys that don't know what a 1995 2120 is. Or think if a filter screws on it's correct.
I know a 1452/1515 fit my 1920. It had a 1515 on it when I got it. Never owned a 2120, though I know they are in the same family, have never seen where its panels are.
Its been ? 12 years since I owned it.. Can't remember where / how it mounted
   / Oil filter for New Holland 2120 #12
Whole different deal than a 1920.
   / Oil filter for New Holland 2120 #13
I knew it was bigger, didn't know it wasn't like a 3000 to 4000 ( is.. Similar 3 cyl, etc ) except in a 4. Thanks for the correction
Was a complete different beast? Rear axle and all?
I miss my 1920
   / Oil filter for New Holland 2120 #14
I miss my 1920
2120 was its own animal except for its less common brother the 2WD economy model 3415. Bigger chassis than a 1920 it had 28" rear rubber and took a bigger loader 7109 / 7309. Optional hydraulic shuttle tranny.
1920 actually shared lots more with its little brother 1720.
   / Oil filter for New Holland 2120 #15
Ahh. That's what threw me off. I've seen a 1720, and thought they looked alike. Never had the chance to see a 2120. Did look at a 3010s one time that I loved. And a 4?50 (3?6?) can't remember. Beefy looking.. Liked it too.
These days my 7610s stays parked. Batwing folded.. Cows n horses eating my pastures, only small 2-4 ac mowing... Use an old loose as a 2bit sloppy hooker 950 with nf for that. ;)
   / Oil filter for New Holland 2120 #16
4630? Maybee been a while.. Think I was a 4630. :)
2120 engine oil filter is parallel to the crankshaft.
Yes it is. It either has a cover over it, or is a cartridge style.
Looking up a NH 2120 with the 2.3L 4 cyl.Shibaura I come up with different numbers for NAPA, Wix, Fram, and Purolator.
Wix lists a NH 2120 with 2.3L Shibaura as using a Wix 51348
NAPA lists a NH 2120 as using a NAPA 1348
OP, look up your 2120 on the Wix site then go to Fram to cross reference the Wix number.
Wix to Fram cross reference can be a Fram 3614,3614FP,7575, or 6016
Purolator cross shows a L10241
I tried cross refrencing the Wix number on Fram site didn't work. Wix called for two different filters, two different sizes for Shibaura engine. I just don't know where to get wix,locally, since I wante to do it this weekend.
NAPA lists Shibura engine, but two filters 1348 and 1349. I might get both. Pictures shows regular screw on cartridge. Not sure if it a generic picture.
On the side of the engine is a blue cylinder, that I assumed was the the filter. Makes me think cartridge or paper filter. As you probably guessed this is my first oil change. ***edit, going off memory, and maybe all wrong.
   / Oil filter for New Holland 2120 #20
Yes, the Wix site listed 2 filters but I ruled out the first one because its a tall filter and someone said a short filter is required. Both use 3/4 - 16 thread. Get one of the others. NAPA 1348 (short filter) is the same as the 51348 Wix. The NAPA 1349 is the tall filter.
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 5055E (A53317)
John Deere 5055E...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
