Oil cooler tip
/ Oil cooler tip #1
CO_Farmer
Loveland, Colorado
Yanmar YM2500
I want to pass along that I recently installed a Perma-Cool #69189 universal oil cooler on my YM2500 and that it fits and works fine (with a minor modification). One benefit is that using the kit lets you use common oil filters with a standard Toyota/Ford 3/4" thread. I'm using the shorter Bosch 3330 filter with my kit because of clearance issues with the power steering cylinder.
The kit includes a screw-on adapter sleeve that transitions the Yanmar filter nipple to the new size that needs to be shortened by 1/4" using a hacksaw and vise. A trial assembly of the cooler adapter to the engine block will make the modification clear.
The cooler itself fits right in front of the tractor's radiator with no problem.
Perma-Cool also makes a #69195 cooler kit that lets you move the filter to another location. Doing that would let you use an even larger oil filter like the common V8 Ford PH-8A or Bosch 3422.
I will say that my tractor runs a *lot* cooler with the added oil cooler when I'm pushing it to the limit when grading our road.
Being able to use more common oil filters was a bonus.
/ Oil cooler tip #2
That's a pretty cool add on. Got any pictures??
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
Wolverine Quick Attach 84" Snow Pusher (A66285)
Wolverine Quick...
2017 Metso Lokotrack ST2.4 Screen Plant on Tracks with Feeder (A65579)
2017 Metso...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
