Oil cooler tip
/ Oil cooler tip #1
CO_Farmer
Loveland, Colorado
Yanmar YM2500
I want to pass along that I recently installed a Perma-Cool #69189 universal oil cooler on my YM2500 and that it fits and works fine (with a minor modification). One benefit is that using the kit lets you use common oil filters with a standard Toyota/Ford 3/4" thread. I'm using the shorter Bosch 3330 filter with my kit because of clearance issues with the power steering cylinder.
The kit includes a screw-on adapter sleeve that transitions the Yanmar filter nipple to the new size that needs to be shortened by 1/4" using a hacksaw and vise. A trial assembly of the cooler adapter to the engine block will make the modification clear.
The cooler itself fits right in front of the tractor's radiator with no problem.
Perma-Cool also makes a #69195 cooler kit that lets you move the filter to another location. Doing that would let you use an even larger oil filter like the common V8 Ford PH-8A or Bosch 3422.
I will say that my tractor runs a *lot* cooler with the added oil cooler when I'm pushing it to the limit when grading our road.
Being able to use more common oil filters was a bonus.
/ Oil cooler tip #2
That's a pretty cool add on. Got any pictures??
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
