Oil Change Frequency?
/ Oil Change Frequency? #1
jlittle
I usually only change my oil once a year on my Yanmar 2500 as it doesn't get heavy use. This year is different and I am wondering how many hours between oil changes? Please advise.
Oops, I found a thread that discusses this issue. Sounds like anywhere between 50 and 100 hours. I have put on about 50 so far. Sorry to post such a question when the answer was to be found.
/ Oil Change Frequency? #3
Most say 100 hours but, i usually err on the side of caution and go 50 hours due to the dusty conditions of 50 hours on my 1700. Others may have different ideas.
/ Oil Change Frequency? #4
I change at 200 hrs or 1 year.I guess it depends on the oil used / usage as to how long to go between changes.
/ Oil Change Frequency? #5
Welcome jlittle,
I change mine based more on calender time because I worry about condensation. May or may not be an issue, but I figure if water can build up in the gas tank, why not the engine block ? Plus, it give me more tinkering time with my Yanmar that way. 62 engine hours this year, oil & filter change twice so far and at least once more.
Where are you from, what do you drive ?
Bruce
/ Oil Change Frequency? #6
Like BruceR, for at least the last 25 years, I've always taken a weekend to service my machines in October and April, regardless of the hours. The tractor and log splitter get an oil change both times. Things like the lawn tractor just get changed in October. Winter machines, like the snow thrower, get serviced in April. The two-cycle machines get cleaned and repaired.
Knute
"Where are you from, what do you drive ?"
I am in Central Illinois, very near Springfield. I have a Yanmar 2500 with loader and about 3 acres. I have more hours on the tractor this year as I am constructing a new building that has an open basement. I should have probably rented a bobcat, but that wouldn't be as much fun.....
I assume when you asked "what do you drive" you meant tractor, but just in case here is what I drive on the street:
2001 Chevy Z-71
1999 Chevy Express Van
1972 Chevy Monte Carlo
1965 Ford Mustang
953D GP Bucket (A68134)
953D GP Bucket...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
KUBOTA B2601 TRACTOR (A65057)
KUBOTA B2601...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
