Oh...No!!!
/ Oh...No!!! #21
Hey CTF, did you try using your differential lock?
/ Oh...No!!! #23
No, beacuse the dealer said to be careful using it (and I still don't understand what it is and how it works...:confused:...I guess I'll have to read the manual again...)
hmmm, i use diff. lock quite a bit on lots of tractors, even on a BX24. It basically locks the rear end and all 4 tires (if in 4wd) to go only strait. I also have had the diff. lock get stuck on before too. You can not steer, even in 4wd, the front tires will just wear. So you have to just drive strait and wait for a "pop" sound, thats the diff. lock disengaging. If used under the rigtht cercumstaces, it will serve you well, it has saved my yanmar from getting stuck many times.:thumbsup:
/ Oh...No!!! #24
Hi
You might keep in mind that a tractor will get stuck way easier than you think even with 4 wheel drive-- and the differential locked....If you just begin to sense a problem stop immediately and back up, or spend some time getting un stuck :) The bigger the tractor the quicker it will stick itself...Tony
/ Oh...No!!!
Thanks, you really know your stuff for being the same age as me!!! :thumbsup:
/ Oh...No!!!
Hi
Yes, as soon as I got stuck I immediately stopped.
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
2025 Mini Bucket Excavator Attachment (A64553)
2025 Mini Bucket...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
