Oh...No!!!
/ Oh...No!!! #21
Hey CTF, did you try using your differential lock?
/ Oh...No!!! #23
No, beacuse the dealer said to be careful using it (and I still don't understand what it is and how it works...:confused:...I guess I'll have to read the manual again...)
hmmm, i use diff. lock quite a bit on lots of tractors, even on a BX24. It basically locks the rear end and all 4 tires (if in 4wd) to go only strait. I also have had the diff. lock get stuck on before too. You can not steer, even in 4wd, the front tires will just wear. So you have to just drive strait and wait for a "pop" sound, thats the diff. lock disengaging. If used under the rigtht cercumstaces, it will serve you well, it has saved my yanmar from getting stuck many times.:thumbsup:
/ Oh...No!!! #24
Hi
You might keep in mind that a tractor will get stuck way easier than you think even with 4 wheel drive-- and the differential locked....If you just begin to sense a problem stop immediately and back up, or spend some time getting un stuck :) The bigger the tractor the quicker it will stick itself...Tony
/ Oh...No!!!
Thanks, you really know your stuff for being the same age as me!!! :thumbsup:
/ Oh...No!!!
Hi
Yes, as soon as I got stuck I immediately stopped.
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
Wooden Wagon Wheel Chair (A61574)
Wooden Wagon Wheel...
17395SFL (A61568)
17395SFL (A61568)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
SOLD- Kubota MX5400 land mgmt package
SOLD- Kubota...
