Off Road Dump Trailers Revisted...
/ Off Road Dump Trailers Revisted... #71
</font><font color="blue" class="small">( As for the tailgate, I have a design in my mind and this weekend I might just get it to hard metal.)</font>
Please make sure to take some photos!
As for the floor gap: I had close to an inch the day it was assembled!
/ Off Road Dump Trailers Revisted... #72
I just more or less finished a swinging tailgate for my Country Mfg wagon and it works like a champ. /forums/images/graemlins/laugh.gif
I still have some cross members to add along with finish welding and cleanup/paint. I hope to have a full set of pics later this weekend, I hope.
Until then, here is a quick teaser shot of work in progress at this time.
/ Off Road Dump Trailers Revisted... #73
Nice heavy hinges. They should take all the banging and abuse you can dish out.
My buddy just bought one of these used, 1 year old, only used by an old lady to haul clean dirt on Sundays. He stole, uh, I mean bought it, for $14K for both the trailer and an F350 to pull it with.
http://www.bigtextrailers.com/spec/25du.html
I can't wait to borrow it from him and see it up close. It will give me some ideas for building a *much smaller* one of my own some day.
/ Off Road Dump Trailers Revisted... #75
Where and what size of hydraulic cylinder did you use for your trailer? I received my trailer and have is assembled but have not purchased a cylinder as yet. I installed the remote hydraulic kit on the tractor, but need to get a cylinder.
/ Off Road Dump Trailers Revisted... #76
I used a Chief 3x24 cylinder from Surplus Center.
I also got two 1/2" to 3/8" reducer bushings and used 3/8" hose with MPX90-06-06 fittings on one end and MPX06-06 on the other end with the 3/8 male QD.
Chief 3x24 cylinder at Surplus Center
/ Off Road Dump Trailers Revisted... #77
I'm reposting some thoughts I had on a recent thread where the subject of off-road dump trailers came up. Essentially one of the posters was looking at putting a Country Mfg. dump wagon on an on-road equipment trailer, then loading the Country wagon with materials (dirt, gravel, etc.) and hauling it. My take on it was that I didn't think it would be a real good idea to be hauling the loaded Country dump wagon on a trailer, over the road.
The first question that popped into my mind was "How do you plan on securing it while in transit ?" (....... with chain binders on four points I hope ?)
I've only had my Country dump trailer for a couple of weeks, and have only been using it for about a week or so since I got the hydraulics hooked up, so I'm no expert but here's a couple of thoughts.
For the price these were recently going for ($750) on their "spring special", they are worth the money in my book. However, after getting an up close and personal look, I would not say that these are the most heavily constructed units ...... the frames are relatively light for what they are doing.
I've hauled over 28,000 lbs of sheep manure about 1200 feet, through a large field and a woods (uneven terrain) from the neighbors in the last couple of days .... going through the field I can move at a decent clip (but then the top speed on my B2910 is only around 11 mph at most - although I'm sure I'm not going half that speed), through the woods I slow down considerably (1-2 mph)
Higher speed (on the road, in a trailer) = more mass moving at a greater velocity = more inertia = more stress on components with any sudden changes.
I have loaded my dump trailer heaping with wet sheep manure .... if it don't weigh every bit of 4K lbs I'd be real surprised ..... and when I go to dump it I can see the dumpbed frame doing some very significant flexing from the sheer weight of the load.
I was in the process of fabbing a dump wagon using an E-ZTrail 2-ton running gear and decided that I needed to be getting something done in the nice weather other than fab work .... so I bought the Country Mfg. unit .... I will finish up the E-ZTrail dump wagon this winter. The bed I've built for it is far more heavily contructed than the Country unit (2"x3"x 1/4 & 1/8 box tube, not angle like the Country.)
After my limited experience I would even say the E-ZTrail (and the probably the Kory) 2 ton gears gears might be a bit light .... I think Larry Van Horn ended up going with a Kory 6 ton running gear as the basis for the dump wagon he built ... probably a very wise move on his part ..... it will probably last and won't get too torn up.
All I'm saying is that treated with some care these units are fine and will probably do alot of work ..... but I don't think they are heavy enough to take a whole lot of abuse. YMMV.
/ Off Road Dump Trailers Revisted... #78
Up ....
/ Off Road Dump Trailers Revisted... #79
.... up ....
/ Off Road Dump Trailers Revisted... #80
... and away ....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
Cat CB24B (A60462)
Cat CB24B (A60462)
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
