Off centerline pulling
/ Off centerline pulling #1
bcp
Super Star Member
SW WA
Kubota BX2360
Not a tractor, but an illustration of a possible danger caused by pulling at an angle.
36 second video:
Bruce
/ Off centerline pulling #2
I would have hated to be the guy that came up with this idea. And, no doubt, there was someone with more experience saying not to do this.
/ Off centerline pulling #5
I leave you alone with the crew for ten minutes and see what happens?
/ Off centerline pulling #6
They didnt have a choice really -- the track just curves right in video. I agree - there must be a better way -- expensive lesson learned
/ Off centerline pulling #8
Totallydifferent circumstances than backing a tractor up @ an angle to another stuck tractor and pulling. Sometimes sharp angle pulling is the only way to get a larger machine out with a smaller one.
/ Off centerline pulling #9
And someone probably got fired for it too!
But, that is what I call an "exercise in futility"! I don't know what they were hoping to accomplish by simply dragging the car up closer to the tracks. It would have still taken a crane to get it back on track, so they should have just gotten a crane in the first place. Bet they will next time lol.
I wonder how long those diesel engines ran before they were either shut down, blew up, or else they hydrolocked (whichever came first)?
/ Off centerline pulling #10
It'd be ironic if the original accident was caused by the cars stringlining that curve.
/ Off centerline pulling #11
Plan B ???
/ Off centerline pulling #12
and first few seconds, i saw the cable twist, and what looked like a one of the strands of the cable went loose... i thought cable was all going to break and whip.
/ Off centerline pulling #13
When I saw them cleanup a derailed train cars they used a crane.
/ Off centerline pulling #14
Looking closely, it looks almost like the rail on the inside of the curve broke or came off of the crossties. If you watch closely, it looks to me like the engine started to slide sideways, then the front wheels caught in the dirt and the other engines pulled it over.
Aaron Z
/ Off centerline pulling #15
If you take a perfectly fine locomotive out and then somehow flop the pesky thing on its side you may want to consider a different way of making a living.
/ Off centerline pulling #16
yeah that was pretty much a disaster, and I am not sure what they thought they were going to accomplish anyway..What was the end result supposed to be?
/ Off centerline pulling #17
I wonder if any of the participants have:
1) Left to spend more time with family.
2) Left to pursue other interests.
3) Accepted a position of increased authority and visibility.
/ Off centerline pulling #18
Or accepted the fact they made "A career limiting decision."
If the RR in question was Amtrak, then I'd say option 3 applied.
/ Off centerline pulling #19
Also, if that pull line had parted, we would have seen several guys cut in half too..This thing was a cluster from the get go..
James K0UA
/ Off centerline pulling #20
Would have helped to take a few hours & drag out & set up a snatch block to get a straight pull.
There's never time do do it right, but there's always time to fix the FUBAR and then do it the right way.
2015 Caterpillar 906H2 (A64911)
2015 Caterpillar...
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
Kivel QA Pallet Forks (A64912)
Kivel QA Pallet...
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
2022 Deere 325G (A64911)
2022 Deere 325G...
