Odometer Problem on a Kubota B7800
/ Odometer Problem on a Kubota B7800 #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Looking at a 2008 B7800. Owner says the tachometer reads a lower rpm (appr. 1500 rpm's)
when he is running the engine at pto speed.
Is there a fix for this?
Will the tractor have clocked less hours than it would have
if the tachometer read the rpm's correctly?
/ Odometer Problem on a Kubota B7800 #2
The tach is cable ran so would say the cable is bad. Yes the hours would be lower.
/ Odometer Problem on a Kubota B7800 #3
Odometer reads miles driven (tractors don't have them usually), Tachometers read engine speed (RPMs) and the greater the speed of the tach, the faster the 'work' hours would show on the hour meter. You could idle for 3 hours and only clock 30 minutes on the meter (as an example), but since knowledge of the engine wear, maintenance intervals and resale value are based off the hour meter you don't know what you're getting.
Buyer beware, but unless it is a really good deal, I would walk away. The tach cable can be fixed, but then you would have to do all of the maintenance immediately so that you had a starting point and known interval after that.
/ Odometer Problem on a Kubota B7800 #4
I agree that the tach cable is the likely problem, but I've also seen tachs not working because the fan belt was slipping. That is, if the tach cable runs off the back of the alternator, and I don't know for sure that's what the B7800 has.
/ Odometer Problem on a Kubota B7800 #5
On old tractors the hour meters were driven off the tach, and would read true at rated rpm. But this is a 2008 tractor. On modern tractors the hour meter is electro-mechanical or electronic and measures the time that the ignition is on (or on really modern tractors with EFI, it's sometimes the time the engine is running). The hour meter on this tractor should be correct unless of course the owner has replaced it or disconnected it for a while.
Tachometers can be mechanical or electronic. Mechanical ones have a cable from the engine, usually from the cam drive. (Alternator cam drives are also an old tractor thing). A bad cable can cause low reading but it's often the gauge itself. While they can be rebuilt, a replacement from Kubota would probably be cheaper. If it's an electronic tach then you'd replace the gauge.
My 1992 B7100 has an electro-mechnical hour meter that is on when the ignition is on. When you turn on the ignition to turn on the glow plugs you can hear and see the hour meter ticking... the "1/10" indicator moves every few seconds.
Thanks for the follow up.
Here is some background. The tractor is advertised with 176 hours.
When I went to see the tractor is noticed the hour meter read 131.5 hours.
The owner told me that when he runs it a pto speeds, the tach only reads around 1500 rpm's.
He is a backyard farmer (maybe 1 acre owned for house, yard and garden) with a 5' tiller, cultivator,
brush hog, potato plow, and a JD single row seeder. From what I see, he has only used the tractor for
this pto work, since new.
My concern, from watching him operate the tractor is that it appears that he runs the tractor at rpm's
that are too high for the task. While demonstrating the fel, and even pulling it our of the garage, the
engine was running too high for all.
Can this problem be caused by the owner running the tractor at high speeds when in use?
He mentioned that the tach problem recently started.
How would I repair this tach issue? And how is the the black plastic "dash cover" removed?
/ Odometer Problem on a Kubota B7800 #7
The "cable tractormeter" (kuboia speak) number is 35300-99343 and is about $25. It is driven off of a gearcase from the front of the engine (See attached)
BUT, be aware that if the cable is not the problem, the meter assemble 6C140-55100 is about $300.
/ Odometer Problem on a Kubota B7800 #8
John - I'm not familiar with the B7800, but I did a repair on my Kubota B21 a couple of years ago. The B21 has a mechanical meter and the problem was at the instrument panel end. The problem and repair are described in my posting with the title "Kubota B21 Tach Cable Repair". Hope it is helpful.
/ Odometer Problem on a Kubota B7800 #9
When I bought my B7800 new in 2005 the dealer told me to always run it at full throttle.I ran equipment for a living all my adult life so I ignored him but had been a "backyard farmer" I probably would have listened to him.
How does this guy know what RPM's it's running at? Does it look like it has less than 500 hours on it?
If the price is right for you and the tractor is in good shape I wouldn't be afraid of it.I have over 1200 hours on mine and the engine has been great. I have had problems with the differential lock and a front axle broke because it was not properly welded when new but overall it's been a great tractor.
You can get a cheap hand held laser tach and check the pto shaft to see what it is actually doing if you're seriously interested in the machine.
Jim-
Owner says the tach works at lower speeds. He said the tach recently started to to read lower rpm's when he ran it at higher speeds.
Looks like new, tires, paint, bucket, seat. Just very dirty from use in the garden dirt running his attachmnets.
/ Odometer Problem on a Kubota B7800 #12
Jim-
Every now and then you will run into a case where lack of use causes problems like this and just running it will straighten them out. It sounds like you have found a diamond in the rough and if the price works and the tractor fits you I wouldn't be afraid of it.I find mine to be a really comfortable unit, for me, and that is what determines a good deal.It has to work for you.
Any idea as to the value of this 2008 B7800 with under 200 hours and in very nice condition?
It will need all new filters and oil changes.
/ Odometer Problem on a Kubota B7800 #14
Just about any used machine will need a complete service for the peace of mind factor so I wouldn't make that a real big deal though it may help a little in negotiating final price. Tractor pricing varies somewhat regionally and the fact that these more desirable units are so seldom on the market makes it hard to gauge. My 2005 model was $17,500 for the tractor,LA402 loader and 54" Gearmore box scraper with top and tilt.If I decided to sell, which I can't see happening,I wouldn't take less than $12,500. My tractor is in great shape, always stored inside and maintained. I'm not sure I would take that $12,500 unless there were extenuating circumstances like health issues etc. ,probably why there aren't many on the market.
/ Odometer Problem on a Kubota B7800 #15
I don't think I would take anything less then $10,000.00 for mine. I have a l4240 and bx2660, but for the small work I also jump on the B7800. That little tractor for it's size can do a big job.
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A66736)
2015 International...
2017 MAC Half Round T/A End Dump Trailer (A68183)
2017 MAC Half...
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
CATERPILLAR PAVER (A65053)
CATERPILLAR PAVER...
2003 FORD EXPEDITION SUV (A66091)
2003 FORD...
2013 MACK CHU613 (A67714)
2013 MACK CHU613...
