o6 gmc canyon engine knocking
/ o6 gmc canyon engine knocking #1
echoman
wv
kubota b2920
My wifes canyon with a inline 5cyl engine with 116000 miles ,has a knocking sound at the front of the moter.Its only at idle as soon as you start to rev it up it goes away.If it was a v8 I would say its a timing chain,but Iam no sure if it has timing chain or a belt.Any suggestions would be helpful thanks
/ o6 gmc canyon engine knocking #2
Not sure but my mechanic has replaced two of these motors in the last 4 month. One on the truck and one on a SUV. Weird setup with the front drive shaft going through the oil pan.
Chris
/ o6 gmc canyon engine knocking #3
any difference with different fuel grades?
soundguy
Soundguy,not a fuel pinging noise. thanks
/ o6 gmc canyon engine knocking #5
soundguy
I am thinking along the lines of detonation or valve train noise. A rod knock would continue thru the rpm band. The lifter in this motor, I am assuming, are hydraulic, maybe one is not "primed" enough at idle but pick ups lube as acceleration is applied.
/ o6 gmc canyon engine knocking #6
Does this have a timing belt inside a cover? When slack, those have the exact symptoms you describe. So the problem could either be the belt or the tensioner (assuming the vehicle has a timing belt, that is).
/ o6 gmc canyon engine knocking #7
It is a chain, not a belt.
/ o6 gmc canyon engine knocking #8
Check idler pulley on serpentine belt.
I bought a Chevy Van CHEAP that sounded like a rod knock and I found the pulley bad.
/ o6 gmc canyon engine knocking #9
That'd be my first check too..They tend to quiet down when the RPM's come up.
Easy, cheap fix.
Thanks for all of the repliys I would have bet a $100 that it was a timing chain,but I would have lost.water pump ,fan clutch,and while it was in the shop,new idler pulleyand belt.$600and change.
/ o6 gmc canyon engine knocking #11
Glad it was a relatively cheap fix.
Chris
/ o6 gmc canyon engine knocking #12
All external reapirs...Not a big thing with the mileage you stated...Could be that the bad clutch took out the waterpump...That happens if it goes on for a while.
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
16ft. Teak Wood Table (A61574)
16ft. Teak Wood...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
Bobcat MT85 (A60462)
(2) FIRESTONE WILDERNESS LE-265/70R16 TIRES (A64280)
(2) FIRESTONE...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
