o6 gmc canyon engine knocking
/ o6 gmc canyon engine knocking #1
echoman
wv
kubota b2920
My wifes canyon with a inline 5cyl engine with 116000 miles ,has a knocking sound at the front of the moter.Its only at idle as soon as you start to rev it up it goes away.If it was a v8 I would say its a timing chain,but Iam no sure if it has timing chain or a belt.Any suggestions would be helpful thanks
/ o6 gmc canyon engine knocking #2
Not sure but my mechanic has replaced two of these motors in the last 4 month. One on the truck and one on a SUV. Weird setup with the front drive shaft going through the oil pan.
Chris
/ o6 gmc canyon engine knocking #3
any difference with different fuel grades?
soundguy
Soundguy,not a fuel pinging noise. thanks
/ o6 gmc canyon engine knocking #5
soundguy
I am thinking along the lines of detonation or valve train noise. A rod knock would continue thru the rpm band. The lifter in this motor, I am assuming, are hydraulic, maybe one is not "primed" enough at idle but pick ups lube as acceleration is applied.
/ o6 gmc canyon engine knocking #6
Does this have a timing belt inside a cover? When slack, those have the exact symptoms you describe. So the problem could either be the belt or the tensioner (assuming the vehicle has a timing belt, that is).
/ o6 gmc canyon engine knocking #7
It is a chain, not a belt.
/ o6 gmc canyon engine knocking #8
Check idler pulley on serpentine belt.
I bought a Chevy Van CHEAP that sounded like a rod knock and I found the pulley bad.
/ o6 gmc canyon engine knocking #9
That'd be my first check too..They tend to quiet down when the RPM's come up.
Easy, cheap fix.
Thanks for all of the repliys I would have bet a $100 that it was a timing chain,but I would have lost.water pump ,fan clutch,and while it was in the shop,new idler pulleyand belt.$600and change.
/ o6 gmc canyon engine knocking #11
Glad it was a relatively cheap fix.
Chris
/ o6 gmc canyon engine knocking #12
All external reapirs...Not a big thing with the mileage you stated...Could be that the bad clutch took out the waterpump...That happens if it goes on for a while.
2021 John Deere S790 Combine (A63111)
2021 John Deere...
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2021 POLARIS PRO XD 4000D UTV (A64280)
2021 POLARIS PRO...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
JOHN DEERE 8245R TRACTOR (A64280)
JOHN DEERE 8245R...
