nortrac dozer trouble
/ nortrac dozer trouble #41
I didn't resurface the fly wheel, do you think it will be an issue?
If in fact there are little "cracks" in it, known as heat checks, then yes, it could be a real problem depending on how deep they are. They indicate a lot of heat build up either from slipping/riding the clutch or a frozen pilot bearing. But maybe I was just seeing things.:)
I do see the same thing you mentioned in the photo, I believe it was more crud then heat though. I did take the flywheel off and look it over as best I could, couldn't find anything that caused alarm. I did not use a magnifying glass or anything like that, maybe I should have?
/ nortrac dozer trouble #43
I belive you are probably OK then. If you would have needed a magnifying glass to see the heat checks, then they wouldn't be a concern. I usually check the runout of a flywheel with a dial indicator to determine if more than just a face cut is required.
Good job! :thumbsup:
:dance1: :drink: :cool2: :cloud9: :D Got everything back together and running, drove it around a bit to make sure everything was good. I then drove it over for some fuel and grease to get ready to put it to work. I hooked up my trailer and loaded 10 logs {8-14diameter by 8.5 to 14.5 feet long} everything worked great. The dozer pulled fine and the clutch worked better then ever.
Thanks again to everyone that helped :)
/ nortrac dozer trouble #45
Thanks for the follow-up with the final resolution! Now I can sleep soundly tonight.:laughing:
/ nortrac dozer trouble #46
Good job getting her fixed.
Chris
/ nortrac dozer trouble #47
Glad it worked out and it's fixed :thumbsup:
iDrive TDS-2010H...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
