Northeast Heating Options
/ Northeast Heating Options #21
Sigarms said:
One thought, duel fuel.
When we built our 2000 sqft house + 1000 sqft above ground basement, we went with a forced air oil furnace and a/c unit. We also have a propane fireplace (more for "romance" than function, but comes in handy when the power is out). We do use electric heaters throughout the house for those cold spots.
I wish now, instead of the a/c unit, I bought a heat pump. This way I could use the heat pump down to 20-30 degrees and let the oil furnace take over when needed. I would of course still have the cooling capability during the summer.
Many people have mentioned they love their in floor radiant heating system. So that might be something to look at too.
Just my thoughts.
Wes
/ Northeast Heating Options #22
Just my thoughts.
Wes
Agreed that in floor radiant is probably the best for heat. Can't beat it. When I worked in the North East, a lot of "upscale custom new construction homes" I dealt with went with radiant floor heat and a high velocity system for A/C. However, it gets EXPENSIVE. Problem with infloor heat is if you need A/C. You then are paying for two seperate systems, and ductwork for the a/c that you don't need for infloor heat.
Honestly, if you get a guy who knows and does geothermal (along with the trench work needed), the cost won't be as bad as you think for a geothermal system. Problem is most contractors are not to familiar with them, and you then have a pretty big "fudge factor" in the cost (particularly with the trench work, because they don't do it on a regular basis).
That said, I changed one of three systems in my house to duel fuel (LP gas furnace/heat pump) with the two others still being LP gas-a/c, and from last year, already saved well over $200 on my LP bill in the first year, even with the price of LP going up (and that was just the upstairs system). Next system will also be a duel fuel on the main floor, or I may go with a heat pump with a pellet/corn/wood stove for back up heat on the first floor.
/ Northeast Heating Options #23
If you can swing it, definitely look at geothermal heat pump systems. At least with them, you can be somewhat confident that you'll be able to keep your house heated even if fossil fuels start to get harder to come by. The electrical utilities can always switch over to things like nuclear power plants or coal if our friends in the Middle East decide to stop playing nice with us... Also, you have the option of going solar later on and telling the utility company to take a hike. Best of all, if you own a backhoe and can dig deep enough to get into the soil that stays at a constant temp, you can cut out a big cost of the installation by doing all the trenching yourself.
/ Northeast Heating Options #24
While geothermal sounds like a good method to read up on and consider, you may want to also read up on gas/propane fired Wall-Mounted Condensing Boilers. (i.e. Viessmann or Buderus brands) They are REAL quiet, need no masonary chimney and are very efficient. If you need to use propane definately purchase your own tank (500 or 1000 gallon) and then you can simply seek bids for the best price and never have to deal with changing out the tank.
You can heat your domestic hot water, run your dryer, gas fireplace, generator, range, etc. Consider radiant heat and no matter what heat source build an energy efficient house!!
/ Northeast Heating Options #25
Hazmat touched on the most important thing, insulation and energy efficient house . Research all the options like ICF construction, hold your window to wall ratio down. Then a small heating system is all you need. Geothermal is a good way to go.
/ Northeast Heating Options #26
I think geothermal technically refers to ground sources of hot water or steam heat, such as hot springs or geysers. They use the term ground source heat pump to refer to systems that extract heat from ground that isn't thermally active.
Bedrock on our property ranges from ground level to about 6', would this create a problem for a Geothermal set up?
/ Northeast Heating Options #28
Good question. It would probably best be answered by a company specializing in ground source heat pumps. Google is your friend. :)
/ Northeast Heating Options #29
My house has a propane furnace.... propane is expensive stuff. I was needed a fill a month on my 500 gallon tank in the winter months. I installed a pellet stove a couple years ago and haven't filled the propane tank since.
There are a lot of energy calculators out there on the net that will help you determine the operating costs for various fuels.
One note the on the geothermal, do you have a pond? I didn't know till after I put in my pellet stove that you can do a 'pond loop geothermal' Similar to ground loop except you drop coils of pipe in your pond. This would have been perfect for me, cheap to put in and my pond never freezes.
Charles
/ Northeast Heating Options #30
I was in a hurry this morning and didn't get to finish my thoughts. BTW I just re-read your post and noticed you said lake property.... guess you do have a 'pond' ;) Not sure if you could use it... might be worth researching.
One thing with a 'central' heating source like a pellet stove is getting the air to other rooms. My house has a 'great room' type living room, it goes up two stories.. this is where the pellet stove is so very helpful getting the heat upstairs. We have ceiling fans in every room and run a few other fans downstairs to push the warm air into back rooms.
Since you are building I would definitley look at radiant floors.... at least in the rooms where your wife spends time.... I never hear the end of how cold the bathroom floor is :rolleyes:
Energy prices are only going to go up so the more efficient your home/systems can be the better, using solar etc. Choice of fuel is always nice... oil boiler with a wood backup etc. Keep in mind that some are more work than others. A wood fired boiler is going to be a lot more work than natural gas furnace.
/ Northeast Heating Options #31
Yep, true but everyone is using it interchangeably . Here is one of the brands I use, check out what they call it.
GeoComfort 1888-436-3783, Geothermal Heating, Geothermal Cooling, Geothermal, Geothermal Power, Geothermal Installation, Geothermal Solutions
/ Northeast Heating Options #32
If you have a large pond that doesn't ever freeze completely, that's a great way to make geothermal work. Also, if you already have a deep well, you can use it as the heat source. Around here, geothermal heat pumps are pretty rare because temperatures aren't too extreme - and because most people don't have the kind of land needed to use trenching to put one of these systems in. Most of them are installed with deep wells that have to be drilled by licensed well drilling companies, and those licensed well drillers can charge upwards of $30K for a single well. That kind of up-front cost is tough to recover if you don't have to use your heat to fight off freezing temperatures all winter long. If you can find a way to get around the well-drilling or trenching cost, the systems are very reasonable to purchase.
/ Northeast Heating Options #33
do not do geo-thermal, especially in the north east. too expensive, noisy and too many parts to break. Insulate the house very well and do not use oil.
/ Northeast Heating Options #34
You must have heard a bad job, you literally can't hear the ones we put in. Warranty is 10 year parts and labor.
/ Northeast Heating Options #35
We will be building a new house, so I have been looking at heating and cooling options. Everything I have seen says ground source heat pumps are very quiet.
Thanks for all the information and ideas. Found a good site for cost comparing on Google,
Alternative-Heating-Info.com
/ Northeast Heating Options #37
We are in the northeast and my neighbor uses geo with a pond loop. It's quiet and he seems happy with it. It wasn't cheap however.
/ Northeast Heating Options #38
That's an interesting and useful site. There is a downloadable Excel spreadsheet that is much more sophisticated that the web page's fuel comparison chart. The spreadsheet appears to be an excellent tool for running cost comparisons between various heating and cooling options. It has provisions for adjusting to local prices and heating/cooling requirements. It also handles both air source and ground source heat pumps.
FWIW, I opened it using Open Office 2.2 with no apparent problems.
/ Northeast Heating Options #39
Based on this thread I was out looking at the evacuated tube solar systems... anyone using one of these for hot water/water pre-heat? Being on propane my water heater is electric as well as the clothes dryer and I have one of those septic systems where it pumps warm air through it all the time. My electric bill never drops below $100/month. Not really sure how much of that is hot water so I am curious if anyone has put one of these systems in and how much it saved them.
Thanks,
Charles
/ Northeast Heating Options #40
I don't know if this will help but seven years ago I built my present house. Currently, 38' x46' . The roof is 8" Stuctual Insulated Panels (SIPS) and the walls are 6" sips. It is basically a ranch that is sunk into the earth (earth bermed) on the north and west side. The east side is basically a 3 car under garage. I heat the 1748 sq ft upstairs That has 15ft catheral ceilings and the future family room downstairs (26' x38') with one woodstock soap stone wood stove. I used 2 - 2 1/2 cords of wood to heat it here just outside of Manchester NH. It is rated at 23000 BTUs to heat. I have radiant floor heat with a 40 gallon propane hot water heater to heat with that I do not use. Currently I have just started the search for venders to switch to solar heated water for both domestic hot water and to use the radiant floor heat.
Jim
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
Rake Master CR-72G (A64119)
Rake Master CR-72G...
UNUSED TAG BTB12518 - 18" PIN ON BUCKET (A64280)
UNUSED TAG...
