No hydralic pressure
/ No hydralic pressure #1
kiotirookie
kioti DK35
Tractor is Kioti DK35.
Just drained and refilled trans/hydro fluid and now have no hydraulic pressuer. Is there an air bleeder somehere?
/ No hydralic pressure #3
You probably have lost the prime. After starting engine, you could add air to the hyd tank filler opening with a blow gun and a rag around the nozzle.
If your system is open center hyd system, you have a path to tank with all valves in neutral.
Thank's J.J.
I do believe you mignt have the solution. I shall try this proceedure and hope for the best.
Regards. Peter (kiotirookie)
Hello Egon.
Yes, the filter was changed along the way. Just got an idea from JJ about forcing prime using air pressure. Thanx for responding.
Regards, Peter (kiotirookie)
/ No hydralic pressure #8
If you use air to prime your pump, just go easy on the air. The trans case is vented and runs with no pressure.
To one and all who offered advice.
It took a while to get back to the tractor problem. Familly issues. Anyway, it was indeed a pump priming problem. The air pressure fixed it virtually immediately.
Thanks to everyone and have a good whatever.
Cheers Peter (kiotirookie)
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
More info coming soon (A61569)
More info coming...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
