No hydralic pressure
/ No hydralic pressure #1
kiotirookie
kioti DK35
Tractor is Kioti DK35.
Just drained and refilled trans/hydro fluid and now have no hydraulic pressuer. Is there an air bleeder somehere?
/ No hydralic pressure #3
You probably have lost the prime. After starting engine, you could add air to the hyd tank filler opening with a blow gun and a rag around the nozzle.
If your system is open center hyd system, you have a path to tank with all valves in neutral.
Thank's J.J.
I do believe you mignt have the solution. I shall try this proceedure and hope for the best.
Regards. Peter (kiotirookie)
Hello Egon.
Yes, the filter was changed along the way. Just got an idea from JJ about forcing prime using air pressure. Thanx for responding.
Regards, Peter (kiotirookie)
/ No hydralic pressure #8
If you use air to prime your pump, just go easy on the air. The trans case is vented and runs with no pressure.
To one and all who offered advice.
It took a while to get back to the tractor problem. Familly issues. Anyway, it was indeed a pump priming problem. The air pressure fixed it virtually immediately.
Thanks to everyone and have a good whatever.
Cheers Peter (kiotirookie)
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
36 BLADE AC CENTER FOLD DISC HARROW (A63291)
36 BLADE AC CENTER...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
