Oil & Fuel No fuel from injection pump
/ No fuel from injection pump #1
Marv
Thumb of Michigan
I just bought a YM1810D from an importer got it home, had to put fuel in it, bleed the air out of the line to the injection pump. No fuel is coming out the pump to the injectors. This tractor has a separate shut off form the throttle, could something be stuck in there to not let fuel out? Or is there something wrong in the pump. PLEASE HELP
Danny,
I tried that, & I also took the line off at the pump but no fuel. Have let out about a quart at the pump bleeder but still no fuel out of the pump
/ No fuel from injection pump #4
break the lines loose at the injectors, pull the decompression knob ( make sure it's working ) and turn the engine over till you see fuel coming out of the line, tighten the line, then tighten the next line when fuel comes out till you get all of them. The fuel may take a while to get to the injectors. Also make sure it is not sucking air somewhere. If you changed the fuel filter then the O-ring could be leaking.
Danny
Parker Equipment Co
/ No fuel from injection pump #5
alot of small pumps loose there prime the easy solution is hooking an electric pump to the suction side of pump and letting it flow. Be careful you can ruin a airlocked pump if keep trying and trying with no fuel running in it..
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
Raven CR7 Monitor (A63117)
Raven CR7 Monitor...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2004 International 8600 Tender Truck (A63688)
2004 International...
