No Ethanol
/ No Ethanol #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Found a local auto parts store that sells ethanol free gasoline by the gallon. At $17.95/gal it's steep but it's 94 octane and guaranteed for 2 years. AvGas at the local airport is $6.20/gal. Think I'll head to the airport come fall.
/ No Ethanol #2
Ethanol free 94 octane is about $3.90 here. Several of the local stations have it.
/ No Ethanol #3
our ethanol free gas is 90 octane $3.78 a gallon i just went and got 15 gallon's today. marathone is our only sorce for it here.
/ No Ethanol #4
Haven't priced it yet, but if you need mixed gas, Stihl has the 92 octane 50:1 Motomix. At least up here in Canada.
http://http://en.stihl.ca/motomix.aspx
Info below, taken from the Canadian site. Must be ultra stable stuff, (at least compared to pump gas today) as they are quoting 2 years after the can is open. Rgds, D.
Motomixョ Premixed Fuel
NEVER WORRY ABOUT MIXING AGAIN!
New ethanol free, fully synthetic and highly biodegradable premixed engine fuel.
Right mix: Perfect 50:1 mixture of 92 high-octane fuel and the protection of STIHL HP Ultra two-cycle engine oil
Longer shelf life: 2 years once seal is broken*
Environmentally Conscious: Non-aromatic fuel; fully synthetic, highly biodegradable engine oil
Extended Warranty: Two year warranty with purchase of 3 cans of MotoMixョ (ask your STIHL Dealer for details)
* It requires to be stored in a cool, well ventilated area to avoid vapour build up. Avoid prolonged exposure to temperatures in excess of 120˚F /48˚C.
/ No Ethanol #5
Ditto, same stuff here runs $4ish a gallon and one station in West Memphis, AR has it around here.
I run it in everything with a carb on it and the difference in ease of starting in performance is simply AMAZING.
I call it Viagra gas for my old 25 horse Johnson 2 cyl / 2 stroke - it makes its sticker peck out!
/ No Ethanol #6
Only 87 oct ethanol free is available at filling stations around here :(
/ No Ethanol #7
I haven't found any ethanol free gas in my area, wish I could. None of the marina's I have talked with have it either. :(
/ No Ethanol #8
There are a number of websites including buyrealgas dot com that list where you can buy ethanol free.
/ No Ethanol #9
Those lists are not updated causing me to take a unsuccessful trip.
/ No Ethanol #10
It is fairly common around here as most of the commercial lawn service companies use it and there is a demand. Also, it is usually readily available around boating areas and runs about a dollar more than the same octane ethanocrap fuel. 100LL Avgas is not a good substitute for modern small engines as the lead causes issues with them. There is some 96 octane racing fuel around in areas with auto tracks. Check the website puregas.org for stations in your area.
/ No Ethanol #11
Plenty of stations around here offering ethanol free gas but just super. The price is about the same price as ethanol super. That's all I buy for the chainsaw.
/ No Ethanol #12
Often the landscaper guys know the ethanol free stations best. They have a lot of expensive small gas engines they need to keep in top shape. I learned of a hometown station that way that I didn't know had ethanol free premium.
/ No Ethanol #17
Nice and Easy in my area has non-ethanol 91 octane. I have 2 vehicles that require at least 91. Just filled one yesterday at 4.14 9/10 a gallon (ouch)
/ No Ethanol #18
According to Pure-gas.org... the nearest ethanol free gas to me is 2 hrs away. :(
Thanks for the link, I will save it and check it occasionally to see if anything shows up closer.
/ No Ethanol #19
I'd have to cross two state lines to get to the closest one to me.
Probably a 2 hour drive, one way, if I time the traffic just right.
If there's an accident, then it's "a three hour tour, a three hour tour".
Until this changes, it's Sta-Bil in the green bottle for me.
/ No Ethanol #20
we have half a dozen service stations selling supreme non ethanol here in north idaho. Runs about $3.90/gallon. 92 octane the last time i filled up
Deutz-Allis D1069-S (A64911)
Deutz-Allis...
CAT 735/740 Final Drive (A68134)
CAT 735/740 Final...
1999 Kenworth W14 (A64911)
1999 Kenworth W14...
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
Giyi SZYMJ QA Mini Stump Grinder (A64912)
Giyi SZYMJ QA Mini...
