no AC can cause big trouble
   / no AC can cause big trouble #1
prairiegirl
John Deere 2950, 7200, Kubota, MF
JD 7200, hot day, air conditioning did not work but oh well, husband is tough, going to pick some bales, Just down the road the tractor runs hot and leaks out all its oil.
Investigate -> AC was seized, so serpentine belt burned through, whacked around and knocked out the engine shaft seal!
So just in case YOUR a/c does not work, don't just sweat ; check the pulley.
   / no AC can cause big trouble #3
Ouch! That stinks!
   / no AC can cause big trouble #4
That could be an expensive lesson!
David from jax
   / no AC can cause big trouble #5
How does an engine run hot and leak out all the oil without the temperature gauge giving a warning???
   / no AC can cause big trouble #7
If the water level drops below the sensor it won't register the high temp. Plus...
The same way the belt noise wasn't heard or the flapping of the belt coming appart wasn't heard. Warning dont matter if you dont pay attention to them.
   / no AC can cause big trouble #8
Sounds like it had water. It had no oil.
I have an open station too. I saved money on the cab, a/c, and a new motor. 😬
   / no AC can cause big trouble #9
Yes it will, steam temperature, and block temperature via thermal transmission.
No cab, so if my A/C doesn't work, we all have a probelm!
We have those too. Also, never dirty windows with cab-less.
he did see the temperature rise so stopped the tractor. Then saw oil trail.
   / no AC can cause big trouble #12
Cabs keep the bees and hornets off you, they keep you cool when its 90 outside, and if you have allergy's, well....
We have both and I prefer the cab tractor.
   / no AC can cause big trouble #13
Maybe the operator had so much sweat in his eyes that he couldn't see the light.
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2012 John Deere 6170R (A57148)
2012 John Deere...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
