no AC can cause big trouble
/ no AC can cause big trouble #1
prairiegirl
John Deere 2950, 7200, Kubota, MF
JD 7200, hot day, air conditioning did not work but oh well, husband is tough, going to pick some bales, Just down the road the tractor runs hot and leaks out all its oil.
Investigate -> AC was seized, so serpentine belt burned through, whacked around and knocked out the engine shaft seal!
So just in case YOUR a/c does not work, don't just sweat ; check the pulley.
/ no AC can cause big trouble #3
Ouch! That stinks!
/ no AC can cause big trouble #4
That could be an expensive lesson!
David from jax
/ no AC can cause big trouble #5
How does an engine run hot and leak out all the oil without the temperature gauge giving a warning???
/ no AC can cause big trouble #7
If the water level drops below the sensor it won't register the high temp. Plus...
The same way the belt noise wasn't heard or the flapping of the belt coming appart wasn't heard. Warning dont matter if you dont pay attention to them.
/ no AC can cause big trouble #8
Sounds like it had water. It had no oil.
I have an open station too. I saved money on the cab, a/c, and a new motor. 😬
/ no AC can cause big trouble #9
Yes it will, steam temperature, and block temperature via thermal transmission.
No cab, so if my A/C doesn't work, we all have a probelm!
We have those too. Also, never dirty windows with cab-less.
he did see the temperature rise so stopped the tractor. Then saw oil trail.
/ no AC can cause big trouble #12
Cabs keep the bees and hornets off you, they keep you cool when its 90 outside, and if you have allergy's, well....
We have both and I prefer the cab tractor.
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
PITTSBURG 2R CULTIVATOR (A63291)
PITTSBURG 2R...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
