no AC can cause big trouble
/ no AC can cause big trouble #1
prairiegirl
John Deere 2950, 7200, Kubota, MF
JD 7200, hot day, air conditioning did not work but oh well, husband is tough, going to pick some bales, Just down the road the tractor runs hot and leaks out all its oil.
Investigate -> AC was seized, so serpentine belt burned through, whacked around and knocked out the engine shaft seal!
So just in case YOUR a/c does not work, don't just sweat ; check the pulley.
/ no AC can cause big trouble #3
Ouch! That stinks!
/ no AC can cause big trouble #4
That could be an expensive lesson!
David from jax
/ no AC can cause big trouble #5
How does an engine run hot and leak out all the oil without the temperature gauge giving a warning???
/ no AC can cause big trouble #7
If the water level drops below the sensor it won't register the high temp. Plus...
The same way the belt noise wasn't heard or the flapping of the belt coming appart wasn't heard. Warning dont matter if you dont pay attention to them.
/ no AC can cause big trouble #8
Sounds like it had water. It had no oil.
I have an open station too. I saved money on the cab, a/c, and a new motor. 😬
/ no AC can cause big trouble #9
Yes it will, steam temperature, and block temperature via thermal transmission.
No cab, so if my A/C doesn't work, we all have a probelm!
We have those too. Also, never dirty windows with cab-less.
he did see the temperature rise so stopped the tractor. Then saw oil trail.
/ no AC can cause big trouble #12
Cabs keep the bees and hornets off you, they keep you cool when its 90 outside, and if you have allergy's, well....
We have both and I prefer the cab tractor.
7ft Fork Extensions (A61572)
7ft Fork...
UNUSED WOLVERINE RSB72-72" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
FORD 5 BOTTOM SIMI MOUNT BOTTOM PLOW (A63291)
FORD 5 BOTTOM SIMI...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
