Nimco Controls freezing
   / Nimco Controls freezing
Here are some pictures...
IMG_0216.jpg[/ATTACH]
I didn't notice until now but in the view from the top there are what look like 2 caps, one over each spool. Should I remove those and check, clean, etc? Also if I want to remove the cable does it fasten directly to the spool?
Thanks!
Is it possible for there to be moisture under the caps?
   / Nimco Controls freezing #14
The most common problem of valve freeze up is moisture under these caps. See arrows on your photo.
If I am to remove the caps for inspection is there any pressure on them. I am assuming the springs, etc are under the caps?
I haven't found a cv number on the unit. I have sent an email to Nimco to see if I can find that information
   / Nimco Controls freezing #17
I think the quickest and first thing to do is unhook the cables like J J said at the valve and make sure its not the cable freezing up before opening up the system.
Ok. So to unhook the cables is it just a matter of winding the nuts off on the bottom side of the valve?
   / Nimco Controls freezing #19
Thanks J J for all the info. I really appreciate all the help. I have looked through all the schematics and haven't seen anything on how the cable connects to the end of the spool.
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
