NH TC40DA just bought ?????
   / NH TC40DA just bought ????? #21
The TC40DAs have a thermostat. Your temp will run in the upper part of the green. I live in East Texas. It gets hot in the summer and I mow all day with it at the same spot.
There is not a radiator screen. Keep the radiator fins cleaned out for max air flow. I wash mine out regularly. I put a hose bid and short hose near the shop to wash the tractor after using it.
Randy you are absolutely correct that there is no screen. Actually the hood has a fine mesh opening and this is also below the battery. There is foam and rubber that is supposed to seal the hood so that all air has to come through those mesh screens and remove most large material. It works good on my tractor, but the radiator always has dirt in it when I wash it out. I take a nozzle and put it in beside the fan blades and direct water out toward the edges of cowling. Looking in front of the radiator, the water always comes out looking muddy. By cleaning from time-to-time, I've never had anything approaching an overheating situation. Engine temperature on our tractors is very stable as long as the thermostat doesn't stick open. If that occurs, the engine will run cold and the gage will never get up to the green area.
   / NH TC40DA just bought ????? #22
I added a fine screen to the front of mine. I cut it large enough so it tucks in under the lips of the radiator and is held there on its own just by this. In addition, being behind the oil cooler, there's some extra protection to keep it from falling out. Only problem is it loads up quickly if I'm mowing/hogging really tall grass that has gone to seed. Always figured though that such is better than sucking in all that stuff and either getting it stuck in the radiator or sprayed all over the engine.
I think my tractor runs more in the middle of the green than the upper part. Probably just the minor differences in the gage, sensor and tractor characteristics and nothing to be concerned about, as long as the radiator is clean.
Thanks for the replies, Repowell what kind of oil is in the front diff?
I had a NH mechanic look at the oil leak i had it is from where the tractor splits apart. The mechanic figured it never sealed from the factory. It hasn't dripped in the garage yet but it is full of dirt around the area. He is going to give me an estimate. He said its alright to run it.
I guess i will have to see what he wants to fix it and how much the dealer will cover?
Is this a common problem for them to leak where the tractor splits? It only has 440hours
   / NH TC40DA just bought ????? #24
ND Teacher, are you actually reading the responses in this thread? I don't mean to give you a hard time, but I answered this question in post #3 of this thread and djradz also posted the answer in one of his responses. The answer is that NH Multi-G 134D is used in the hydraulics, differential, front axle, and power steering. There is NO PLACE that 80W90 is used on this tractor. You only need engine oil, Multi-G 134D, and grease for lubricants. You might want a can of WD-40 and some white lithium grease for spot lubes, but those should be your personal choice.
Yeah i am reading them, I spaced it out it was left out of the last oil post, so with out thinking i quick responded with another question. I Just need to go to NH and buy some oil so i can see the container and know which goes where. i am reading these on my breaks from time to time. I am pretty wrapped up with this oil leak. I am planning on a trip to Bismarck on sat. to purchase oils and filters etc, but i need to purchase an owners manual and the mechanic said he would look around and see if he could find one, I found three filters on the tractor, but if he has to split it to reseal it i might have to replace the oil anyways.
THis website is giving me so much info its almost too much to digest. Friday night i plan on rereading all these posts and make a shopping list from there.
   / NH TC40DA just bought ????? #26
Yep, your head must be swirling with questions. I just couldn't resist giving you a bit of kidding about the differential oil question. ;)
BTW: If you buy grease at anywhere but your NH dealer, make sure it meets NGLI-2. There are lots of NGLI-1 greases at farm stores and auto stores for not much money. The NGLI-2 is a bit more expensive. Here's a link to NGLI grades.
Problems with my seat?
Not sure what the handles do correct me if im wrong
Center grey one with a handle that flips out(lock) Is if for the weight adjustment?
Turn knob below that black in color 3pt speed(hydrualic pressure)?
Grey handle low on the right hand side(to slide seat forward)
Grey handle directly on the left side of the seat(rectangle and grey)???
All handles are freed up and moveable but i cant get the seat to adjust forward or backwards. I sprayed the mechanical parts with JB-80 penetration oil but not freed up yet. Tried to work it back and forth but it will probably have to sit overnight and resprayed in the morning.
   / NH TC40DA just bought ????? #28
My seat gets a little hard to slide sometimes. I find it easier to lube it and work it free by standing next to the tractor and work it back and forth a few times. Less weight on the rails that way.
I think the seat handle on the left side allows the seat to pivot 10º and 20º both left and right. That's for those times when you're looking back a lot.
   / NH TC40DA just bought ????? #29
Lube chart.
I was at the NH dealer and the chart they printed out recommended 10w30 i was thinking 15w40 Is there an oil weight that the op manual recommends? I bought case oil cause they didnt have 10w30 in NH oil on hand. I still havent changed the oil i would like to put in what is recommended but your chart has a few different weights.
I also bought a block heater that i plan on installing soon.
Owners manual should arrive in my mailbox this week.
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A49461)
2008 Ford F-450...
2005 Ford F650 SVI Crew Cab Fire Truck (A49461)
2005 Ford F650 SVI...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
