NH TC40DA just bought ?????
   / NH TC40DA just bought ?????
What the scoop with the oil light and timer?
I also noticed when i start it up at first it revs up a little and then goes down to where it almost stops and then up and down i usually bump the throttle up a little, Like we did on our farm tractors. I figured a 2005 model would idle a little better when first cranked over.
While i was under the tractor i noticed some rust on the bottom side of the platform. Is this common for a 5 year old tractor? Is there any way of preventing this? I suppose removing the rubber mat would help cause it wouldnt trap the moisture.
It doesnt seem like it should be rusting away already
   / NH TC40DA just bought ????? #13
Check your manual, it probably says to bump the throttle before starting. Regardless, you might try around 1,000 rpm or so, should idle smooth at that speed. As already recommended, the synth motor oil will make you feel better about it revving when first started.
On the platform, I don't know. I have a 18 year old Ford and it's not rusty under the platform. Probably pretty hard to clean up. I would check under the mat to see what the top looks like, and at least clean and protect that if it's rusty. Do you know where this thing spent it's baby years?
Jim
Behind the seat had a dealer tag from New York, I purchased it from a dealer in Virginia. I dont know how much salt they use on the ice there, but im thinking salt water air?
   / NH TC40DA just bought ????? #15
Concerning the idle at start up--when cold, mine oscilates up and down. As mentioned, bumping the throttle a little until it's at about 1k helps. After a min. it smooths out. Now we don't get as cold as you do but once it drops below 30 it's normal for mine to act that way.
Concerning the deck--Mine is starting to rust on the bottom also. 10 yrs. old and has had a rough life. And it never saw any salt. I plan to remove the deck (if that's possible) and have it sand blasted and then repaint it. I need to catch mine now before I put my foot thru the deck.
Concerning the diff. lock--It had to have been designed by short legged folks and I'll bet it's awkward for them also. I'm over 6' and all legs with a touch of arthritis in my knees and ankles. It's sometimes painful to engage that diff. but I'm glad it's there.
Later,
I have to keep my foot on it to keep it working the whole time. I am 5'8" and it is a pain for me as well.
If you pull the deck off let me know how it turns out, I am thinking this would be a good project this summer while there is still somthing to save. But that could be a **** of a lot of work too didnt look at it that closely
   / NH TC40DA just bought ????? #17
Congrats on your purchase. I have a 2005 TC40DA HST.
The owners manual says:
Push the throttle to 1/4 to 1/3 open before starting.
Don't engage the starter for more than 30 seconds. Doing so may cause starter motor failure.
Push down on the diff lever to engage. Lift up to disengage. If it is still engaged after lifting either:
1. decrease drawbar pull by raising or disengaging the emplement or
2. rapidly apply and release a light braking load to the slipping rear wheel
Capacities
Fuel 13 gallons
Cooling system 8.3 quarts
Oil with filter 6.3 quarts
Rear axle & transmission (including hydraulics) 9.6 gallons
Power steering 1.5 quarts
Front axle Diff 5.6 quarts
Hope this helps.
   / NH TC40DA just bought ????? #18
Idle - Put the throttle lever about 1/3 to 1/2 way up to start. Not sure what the manual says regarding this, but I don't think I've ever started any of my tractors without some movement up. What I did on my 40D was find where it runs at about 1500 rpms and mark that spot with a marker, so I move it to that exact position to start every time. My 40D (and I presume all of them) have a little problem with the governer not working well, especially when cold, at less than 1000 rpms. As you note, it gets better when it warms.
Deck - there are countless reports of the Class III boomers having paint and rust problems on the underside of the platform/deck. In the early days of TBN, I think I even recall where someone got a new platform from their dealer as a result of it being so bad on their tractor. Mine, a 2001 model, started chipping/flaking, with rust underneath the paint, after the first year. My tractor has never sat outside overnight, nor left wet. I attributed the problem to poor metal prep, maybe even painting over rust, or problems with all these low VOC paints used now, which maybe don't have the same rust inhibiting nature as good old oil enamels. I guess if water where to get under your rubber mat, and stay there for some time, it contributes to the problem, but for most of us, that is not the real problem. In fact, on mine, the flaking started on areas well away from the rubber, on the bottom, and typically on the bracing. I've attached a few pictures taken when the tractor was only about a year.
Differential Lock - yes you need to keep your foot on it, or else it disengages. This may be a bit awkward, but I don't think you'd want it otherwise, less you forget it's on and damage the tractor. The older Ford 1310/1320 - 2120 tractors had the pedal in the exact same position and I think it was thought to work OK, so the design has just continued. Probably the thinking is that you are only using it on rare occasions, so keep it out of the way. I personally like it there.
   / NH TC40DA just bought ????? #19
I noticed this rust about two weeks after buying my tractor. I think the factory just paints over the rust and lets it go. Huge sheets of paint flaked off my platform, but it is so thick that I don't ever expect it to be a problem. Is sure looks nasty though. Here is a picture of my parking brake pawl and you can see the rusty platform. I've had the rubber mat off the top and it looks fine. I have no idea why the bottoms of so many platforms are rusty like this.:(
   / NH TC40DA just bought ????? #20
The TC40DAs have a thermostat. Your temp will run in the upper part of the green. I live in East Texas. It gets hot in the summer and I mow all day with it at the same spot.
There is not a radiator screen. Keep the radiator fins cleaned out for max air flow. I wash mine out regularly. I put a hose bid and short hose near the shop to wash the tractor after using it.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
3in Poly Pipe (A49461)
