newbie seeking advice
/ newbie seeking advice #41
Hmm.. still no reply...
soundguy
/ newbie seeking advice #42
randyvl said:
rub it till till its almost bleeding, wash with chlorox.
kills it every time
Watch it. Chlorine is bad for the thyroid.
larry
/ newbie seeking advice #43
638 said:
Sorry Soundguy, 2 inches is 2 inches. If you cut 10 inches off of the inside tube and 2 inches off of the outside tube, you have not shortened the shaft 12 inches. 2 inches off the outer and 2 inches off the inner shaft will have shortened the shaft 2 inches.
ron
The collapsed length of the shaft changes by the smaller cut. The working length changes by the total of the cuts.
larry
/ newbie seeking advice #44
638 hasn't posted back yet.. he must still be going over the string expirement try to find a way to make it not work...
soundguy
/ newbie seeking advice #45
SPYDERLK said:
The collapsed length of the shaft changes by the smaller cut. The working length changes by the total of the cuts. larry
Larry is right and in this situation it is the collapsed length that is important for getting a shaft attached and usable without binding (collapsed).
He probably decided that it was not worth the time arguing over something so prosto!
Mike
/ newbie seeking advice #46
larry
Best to stick with the "Tecnu", I buy it by the qt bottle. That will last for the me for the season.
John
/ newbie seeking advice #47
Mike
Especially when incorrect!
soundguy
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
2009 Volkswagon Jetta Sedan (A64557)
2009 Volkswagon...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
International (4) Section Rotary Hoe w/ Cart (A66408)
International (4)...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
