newbie seeking advice
/ newbie seeking advice #21
I cut mine to fit. Make sure there is at least 6" of overlap in the longest position.
/ newbie seeking advice #22
I would like to second the post about clorox for poison ivy.
Some years ago I got a good case of poisoning from contact with Manchineel Apple after vacationing in the Caribbean. It is worse than Poison Sumac. Doc gave me a double dose of prednisone, but it did little. I was turkey hunting out of state, and the itching was unbearable and kept me from sleeping. My hunting buddy suggested clorox, and I was desperate enough to try it. Man, does it work! It stopped itching immediately and healed quickly.
I agree with the others that proactive measures to wash the sap/oils off asap is good sense and is what the experts suggest. Prednisone helps when you have got it bad, and the clorox stops the itching and seems to knock the inflammation back as well.
/ newbie seeking advice #23
I was using Clorox on mold several years back and had some nasty burns where it touched my skin around the gloves I had on???
/ newbie seeking advice #24
Obviously everyones skin reacts differently to different acids and alkali's.. some people are more sensitive than others.. I know guys that work with straight chlorine with no problems.. etc.. and others that the mere smell of bleach will send them into a coughing frenzy..
soundguy
/ newbie seeking advice #25
eblanks said:
Thanks again for all the helpful advice, I have a follow up story and additional questions. I purchased a used bush hog and trailered it up to the farm this past weekend. After dealing with some tractor starting issues (loose ground wire) I got the hog hooked up and off the trailer, then went to hook up the pto shaft and - you guessed it - too long. I have an over run clutch on the pto from the tractor. And everything I have read indicates this is a necessity for operating a Bush Hog, so it stays. The PTO drive shaft to the bush hog has a slip clutch, which I understand is preferable so I would like to keep that as well. My question is, I have read that it is possible to cut a PTO shaft to reduce the length. Is this advisable? Is it a difficult process? I'll buy a new one if I have to but would rather use the one I already have. Any thoughts would be appreciated.
The overrun clutch is needed on many older tractors due to the way the PTO works (so the rotation of the bush hog blades don't keep pushing the tractor forward when you really want to stop). A slip clutch is preferable just so you don't have to potentially keep replacing shear pins. You should check that the slip clutch really works.... they can get rusted into immobility then something breaks instead of the slip clutch slipping.
The PTO shaft can be cut with a hacksaw. Be sure that the shaft is long enough so in both raised and lowered conditions there isn't any binding; usually a minimum of 6" overlap (as someone stated) is good in the position where the shaft is as long as it gets. You do not want the shaft to separate while the PTO is engaged.... I don't suppose this has a PTO shaft guard either?
/ newbie seeking advice #26
Are you sure that you need the over-run clutch? Most 3000 ford's didnt need one, the 8N & 9N did. Simple way to find out is take the over-run clutch off connect the PTO shaft get the bush hog up to speed and tractor in gear push the clutch in . If the tractor can be stopped while the bush hog is spinning you dont need an over-run clutch.
A bush hog, if you can drive over it it will chop it. Larger trees you need to ease it on to it. When I say larger trees i mean 4"to 5" trees. I know that the safety police will have a field day with what I just said but it will cut it. Just make sure no one is around when you do it, it will throw wood everywhere.
/ newbie seeking advice #27
There were about 4 trans options on the 3000... at least 2 of them were transmission pto...
soundguy
The overrun clutch was installed on the tractor when I bought it, so obviously the previous owner thought it was a good idea to have it on there. As far as removing it goes, I tried, but can't find any mechanism that locks it in place. There are two grease fittings, I took both off but the OR clutch is still locked firmly in place. I replaced the fittings. There is no other obvious knob, button, bolt, or whatever to get the thing off. The PTO shaft has a shield but admittedly it's a bit worn and has several cracks and missing pieces. I'm headed up to the farm again this weekend, I'll try cutting down the PTO shaft and see what happens, if all else fails there's a tractor supply store nearby, I'll hit them up for some assistance.
/ newbie seeking advice #30
I had no trouble using it twice a day, but as soundguy said we're all put together in different ways.
Something that has worked for me as an alternative to scratching is to (when you can't stand it anymore) apply very hot water to the area. I mean HOT. You can use a folded washcloth if you can't run water on the area. It seems to relieve the itching temporarily, just as if you scratched. Doesn't heal the rash, but it's better than clawing holes in your skin. I get it bad, so I've tried about everything.
/ newbie seeking advice #31
On the ORC removal.. ya got 95% there and then stopped!
Onc ethe grease fittings are removed, rotate the outter portion of the ORC till you line up the ports with a hole thru the inner portion. Int hat hole will be a spring-roll pin.. may be packed with grease.. use a nail as a probe... simply get a drive and drive it all the way out... the the orc can be snatched off.
soundguy
Weekend operations were a success. I wanted to post another follow up story to let everyone know how things went this past weekend up on the farm. Special thanks to Soundguy for your advice on removing the overrun clutch. Once that came off the PTO shaft fit like a glove. Unfortunately I found out quickly that I need the overrun clutch. I didn't have the tools with me to cut the pto shaft down so I did what work I could do in open spaces and just allowed plenty of room for the tractor to come to a stop with the bush hog turning. Speaking of the bush hog, I now have a new found respect for the power and violence that thing is capable of. I would like to think I did my homework before operating it, but I don't know that anything short of experience will prepare you for the damage that thing is capable of. I made sure to stay on the tractor while it was in operation and I started cutting grass and briar patches first, then worked up to some smaller sapplings. So once again, thanks for all the helpful advice, I managed to get the work done without getting injured or tearing up my equipment. I guess that is about all you can ask for.
/ newbie seeking advice #33
Good luck, stay safe and get the shaft sized.
soundguy
/ newbie seeking advice #34
Learned a little from reading this thread!
But re: Poison Ivy (PI). I have PI on my place that I've had to cut with an axe, 3-4" diameter up the sides of trees (I bought an abandoned tract next to my home... I must be a glutton for punishment!). And I get it bad.
My daughter is a registered nurse, honors graduate, and she absolutely squashes the idea of using scalding water. It does feel really good - we used to do it - but what it's doing is activating the histamines (if I remember this right) and making things far worse in the long run. So don't do it. She also frowns on the Clorox, due to the possibility of chemical burns, but YMMV.
My protocol when facing PI: I "dress out" like I'm going into a nuclear reactor vessel. Paper suit with hood, disposable socks or sleeves up the pant legs and arms, tape around the boots and gloves, and I'll even don a hard hat with drop-down face shield if I have to. I may look like I'm heading for Mars, but I get it bad, and avoiding contamination is the best way. Technu on any exposed skin, and even on hands, wrists and ankles, is a great preventative measure as well. The stuff rocks.
If I don't have a paper suit, I still tape up- I use old sock tops as sleeves, and duct tape around everything. When I undress, I go very carefully and avoid touching any of teh possibly contanimated outer clothing with my bare hands. And you must go carefully, because as you undress you can transfer some stuff to the inside.
My wife washes it all separately (bless her heart), including the gloves, and I haven't had a bad problem for a while now.
Try not to cut it in a way that shreds and flings it. That's hard with a bush hog, granted... And whatever you do, don't burn it. My now-retired boss nearly died when younger after he and his dad did this, and the smoke got in his lungs.
I have made my first attempt at resizing the PTO shaft and after doing so a question occurred to me. I have read that you take equal lengths off of both ends of the shaft. So if I need to remove a total of 4 inches length, do I take 2" from one side and 2" from the other for a total of 4". Or do I remove 4" from both sides. I err'ed on the side of safety and only removed 2" per side, but if that only nets me a 2" reduction then I need to cut again.
/ newbie seeking advice #36
You done right.
2" off each side lets the colapse together for a net reduction of 4".. just remember to cut the plastic shields back as well, if they will bottom out befor ethe shafts do.
soundguy
/ newbie seeking advice #37
Sorry Soundguy, 2 inches is 2 inches. If you cut 10 inches off of the inside tube and 2 inches off of the outside tube, you have not shortened the shaft 12 inches. 2 inches off the outer and 2 inches off the inner shaft will have shortened the shaft 2 inches.
ron
/ newbie seeking advice #38
Nobody said to cut it unevenly.. I said to cut equal portions off each telescoping shaft... try this ez and cheap experement:
Take (2) 2' pieces of string, and a tape measure.
lay the strings end to end, overlapping 6" in the middle.
the end to end measurement is 3' 6" ( even though you have 4' of string.. see whats happening here? )
now... say you want to shorten the total end to end length 6"... try this...
cut 3" off each string, and then reset that 6" overlap...
measure the end to end distance... what is it? .. it's 3'..
IE.. 3'6" - 6" cut in equal parts ( 3/3) from the string.
soundguy
EDIT: hit this link.. it's a pdf manual for a king kutter mower.. see page 17-19 for info on how to cut the shaft in equal parts... this was the only company I could find offering a manual online.. however my other 3 mower manuals use the same general practice as in this manual.
http://www.kingkutter.com/downloads/manRKRK.pdf
/ newbie seeking advice #39
Hmm.. quiet....
soundguy
/ newbie seeking advice #40
Hey 638.. how'd the string trick come out???
soundguy
