Newbie needs 3pt hitch advice
/ Newbie needs 3pt hitch advice #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
Hi Gang,
I just hooked up my first rear attachment on my 4300, a King Kutter 30" dirt scoop, and everything went well. Most of it was pretty obvious, but there's one thing I'm not clear about.
In the tractor manual, it mentions the three positions that the tractor end of the top link can be mounted in; the bottom one for light loads, the middle for medium to heavy loads, and the top one for very heavy loads. I experimented a bit with the top and bottom mount position, but it wasn't obvious to me, at least with just the scoop attached, why one would use anything but the position for heaviest loads.
I'm sure there's a reason.. but this is one of those cases where the tractor manual tells me how to do something, but not why I might want to do it. The manual assumes some knowledge on my part, and it makes too charitable an assumption. /w3tcompact/icons/smile.gif
In short, what are the advantages of using either of the other two positions?
TIA,
Bob
Bob Trevithick
/ Newbie needs 3pt hitch advice #2
I think that the trade off must be weight vs. range of motion. i.e. In the light implement setting, I think that you can lift your implement higher than you can in either of the other two.
rf33
/w3tcompact/icons/wink.gif
Yeah, that makes sense. Just from the standpoint of geometry, I guess that would be the only possible trade-off. I'll leave it on the heavy position until I find myself needing to lift something higher, and then experiment some more.
Thanks for the advice!
Bob Trevithick
/ Newbie needs 3pt hitch advice #4
I am not real sure about that, just a semi-educated guess as to why the multiple positions. It makes sense to me that that would be the trade-off, but hopefully JMIII or one of the other experts would give an authoritative answer. The more I learn, the less I realize that I know.
rf33
/ Newbie needs 3pt hitch advice #5
I'm not one of those experts, but I figured I could do my part to add to the confusion.
Mine has four possible positions for the top link, and the manual indicates that the third from the top would be used with plows, so I use that for my middle buster. And I use the top position for everything else - which includes a box blade and post hole digger to date. I had the idea - don't know where I got this idea, BUT - I had the idea that it wasn't an issue of weight so much, because weight goes on the lift arms. But putting the top link in different positions changes the geometry of the hitch in such a way that the "angle of attack" of the implement throughout the range of travel is affected. Wow. That statement's not even clear to me, right now, and I don't know how to make it clearer without drawing pictures. Let's see. For a given lift position, changing the length of the top link changes the angle of the implement - lengthening the top link tilts it back, shortening tilts it forward. But that angle also changes as I raise and lower the implement. For example, if I set the top link to make my box blade level, front to back, with the box on the ground, then the box will tilt back as I raise it. I think. The computer's in here, and the tractor's out there. But I think the way that angle changes as the implement moves up and down changes when the top link's in different positions.
Another guess ;) on why different positions are used - I notice when using the middle buster that when the top link is in lower position, the link is more in compression (stronger) and less in shear than when the link is in the higher positions.
That's two guesses. I will now take my seat and wait with the rest of the class for revelation from the sage. ;)
Steve
/ Newbie needs 3pt hitch advice #6
The tph is a classic four bar linkage studied ad-nauseum in mechanical engineering (which I've long since forgotten). The tractor is one bar (from arm pivots to top link pivot), the lower arm is a bar, the implement is a bar (from lower pins to top link) and the top link itself is a bar. Changing the top link on the tractor changes the geometry of the whole arrangement and probably affects lift height, lift capacity and arc of the implement. (BTW, the rockshaft and lift links are a completely seperate quasi-four bar linkage)
Think of a square with one vertical leg the tractor. Being a perfect square, if you lift the opposite leg it will remain parallel to the fixed leg. If you shorten one leg, the outer will no longer remain parallel as it moves.
I'd have to refer back to my old books to figure out what this really means on a tractor. Sorry, but it's my last day of work this year and it's way to early in the morning for that kind of brain excercise /w3tcompact/icons/smile.gif
/ Newbie needs 3pt hitch advice #7
I don't know if a 4300 has draft control on the 3 point hitch, but that would be a very good reason for different top link connection points. This would be used to adjust the amount of draft feedback to the hydraulics, with heavy loads providing less feedback than light ones.
<font color=blue>...I don't know if a 4300 has draft control on the 3 point hitch, but that would be a very good reason for different top link connection points.</font color=blue>
Hmm. I have "draft links." I see no mention of "draft control." I need to do some more reading to find out about this draft control, but as far as I can see so far I don't have it.
I'm guessing this is come kind of feedback mechanism to keep ground-engaged implements at a constant depth?
Thanks,
Bob
Bob Trevithick
/ Newbie needs 3pt hitch advice #9
Bob, That's exactly what it is. The old Ford 8N tractors had draft control. The JD 4300 doesn't. I just use whatever hole is the handiest when I hook up an implement, usually the middle one. My post-hole digger has to be hooked on the top hole. As far as figuring out the geometry of it all, it just takes too much energy LOL.
/ Newbie needs 3pt hitch advice #10
Bob:
Estif should have it right in his first assumption. Alters the angle of attack.
Egon
<font color=blue>...Estif should have it right in his first assumption. Alters the angle of attack.</font color=blue>
Yes, this makes the most sense to me also. I'm curious though.. what do other tractor makers say about this in their manuals? All my Deere manual says is that it's a weight issue. Do any of the other brands offer better/different explanations?
Thanks,
Bob
Bob Trevithick
/ Newbie needs 3pt hitch advice #12
<font color=blue>Do any of the other brands offer better/different explanations?</font color=blue>
Yes and no, Bob. I've used a number of tractors with the 3 holes for the top link, but my B2710 only has two. And the manual shows the top one as (1) and the bottom one as (2). Then it says (1) is standard. (2) is used only when there is some obstacle that prevents you from using the standard. I don't think I'd consider that a <font color=blue>better</font color=blue> explanation, but at least it is <font color=blue>different</font color=blue>./w3tcompact/icons/laugh.gif
<font color=blue>...Then it says (1) is standard. (2) is used only when there is some obstacle that prevents you from using the standard. I don't think I'd consider that a better explanation, but at least it is different.</font color=blue>/w3tcompact/icons/smile.gif
Well, this supports my idea of using the top position until something compels me to consider using one of the others.
Thanks, Bird. And thanks for seconding the duct tape suggestion for my recalcitrant fuse box door. /w3tcompact/icons/smile.gif
Merry Christmas, you guys!
Bob
Bob Trevithick
/ Newbie needs 3pt hitch advice #14
hi bob, looks like you have alot of input on this subject. will how about some more. my manual says"the top and middle are for attaching the implement without drawing", "the middle or bottom is for attaching with drawing" and the top should be used when driving the tractor on field roads". the last one i'm not quite sure what they mean but if you have no draft control on your 4300 (god only knows why jd did that) then it makes no difference where you attach. so go for the middle that's what i use. my kioti dk35 came with draft control standard. sorry i couldn't hold back.
JB
Hi JB,
Okay, now I'm totally confused!! /w3tcompact/icons/smile.gif
I may end up having to figure out the geometry to make any sense of this. The manuals might as well have said "We put in this feature. We don't know why, but it seemed like a neat thing to do." LOL!
Thanks,
Bob
Bob Trevithick
/ Newbie needs 3pt hitch advice #16
Draft Control for the 3 point hitch is typically not standard equipment on compact utility tractors. It is available as an option on the JD 4500-4700 but not on the smaller 4000s. Its function is to cause the hitch to slightly raise or lower to compensate for variations in soil draft load from a tillage implement such as a moldboad plow, disk, or cultivator. It trys to do automatically what an operator would do by "feathering" the position of the rockshaft arms to try to keep the tractor moving at a steady speed. Note that this is useful only if maintaining absolute depth is not essential.
Draft control and Position Control are not the same. Most compact utilities have position control. Some on the smaller end of the range do not. With position control, the angular location of the hitch control lever in the slot corresponds to a unique angular positon of the rockshaft arms. Thus you can always reset to the same depth by moving the control lever to the same position (usually determined by setting a depth stop.)
The specifications of the hitch of Kioti tractors on the website www.kioti.com indicates that position control is standard, but no mention of an optional draft control is made. This is not to say it is unavailable--just that it isn't mentioned in the specs published on the web.
Earlier posts here have already described the most noticable effect of the various hole positions for attaching the top link to the tractor--choice of hole allows variation in the pitch or "angle of attack" of the implement. Choosing a high hole means the implement will raise and lower with relatively little change in tilt. Choosing a lower hole for attaching the top link (same length as before) to the tractor makes the rear of the implement tilt upward more thus giving more ground clearance when it is raised. Sometimes this is needed on implements like scraper blades to allow enough ground clearance when driving onto ramps when loading onto a trailer.
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
2022 EZ-GO ELITE...
2004 John Deere 544J Articulated Wheel Loader (A64553)
2004 John Deere...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2020 BOBCAT T770 SKID STEER (A65053)
2020 BOBCAT T770...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
