Newbie concerned about snow
/ Newbie concerned about snow #1
Friver
After reading many, many posts on here, I am closer to buying but still looking for advice. I am a newbie at the tractor world and like so many others, started looking at the BX24 and have worked my way up to B2630 or B3030 with a FEL, Backhoe and snowblower.
I plan on leaving tractor at my 2nd home in the mountains. I also have another piece of property very near my 2nd home. Both are a couple of acres. At the 2nd home, the drive way is asphalt and is about 300 feet. The other piece of property – also a couple acres, is where I plan on building a new home. I am currently building a large garage/workshop (toy barn) on this property. there is a gravel driveway (300 ft) here, and it will remain gravel until I build a house in a couple of years. The Tractor will be left in the garage/workshop (toybarn) with the gravel driveway
The land is fairly flat, in a wooded area that gets lots of snow. As I mentioned, this is a 2nd home, so I am not there to take care of the snow when it falls. I often arrive to find 4 foot of snow in the drive way. The tractor will be garaged, but will have to dig its way out from the garage/workshop (via the graveled driveway). The snow may have fallen, melted some, froze some etc., so there will likely be large chunks of ice to remove. This is particularly so near the end of the driveway where the commercial road plower has piled up a berm while making his passes on the road. Once I dig the gravel drive out I can then run the tractor down to the other piece of property and work on its driveway. One concern I have is whether to get a front or rear snowblower. I have read many posts on this, and I understand the pluses and minuses of both – my neck doesn’t turn as well as it used to. In my case though, I am leaning towards the rear mounted blower so I can use the FEL to help with ice berm removal. The berms get to be 4 or 5 feet high and pretty much solid ice. Do the rear and front mounted blowers have the same snow/ice blowing power? Do they work okay on a gravel drive? Do you think the blower can take care of the ice berm? If so, I would be more inclined to get the front blower. Also, how hard it is to switch from a front mount blower to the FEL and back again?
Any suggestions on this would be greatly appreciated.
When the snow is gone, I have a fair amount of lot preparation to do - earth moving (loose soil – no rocks). The land has lots of pine trees on it, many of which will have to come down, so stump pulling/digging will be a necessity. I also have to dig several ditches, prepare for a new house etc. In a couple of years, the tractor will be used primarily for snow removal with some lot clean up etc.
This is a great forum for someone like me. I like to buy quality equipment and it is great to be able to read about other peoples experiences before writing the check.
Friver
/ Newbie concerned about snow #2
Hey Brother...... Those BX24's are fine tractors, but would it be enough for what you have planned?
/ Newbie concerned about snow #3
Well you definitely moved beyond the BX with that description. Also if you are going to run a blower, you better step up to the B3030. You are going to want plenty of HP to blow 4 foot of heavy snow. I would personally do the rear blower for the very reason you mentioned above. :)
/ Newbie concerned about snow #4
I'd also go for the bigger tractor and rear blower.
How about winter temps and starting?
Thsnks for the replies,
I looked at the BX24 but had to rule it our due to ground clearance. I am in a very "woodsy" location and a lot of what I have to do will require maneuvering the tractor over rough ground.
I am figuring on getting a block heater to help with starting. The temps get down below zero fairly often and the tractor will be sitting for long periods of time (weeks) between uses.
I have read some posts about "grapples" for the FEL and that definately has my interest. The limbs from the pine trees will have to be piled and burned (burned after they dry). The grapple looks like a great way to deal with the limbs.
Anymore ideas or suggestions appreciated.
Friver
/ Newbie concerned about snow #6
I take care of about 700ft of a good gravel drive with a rear mounted snow blower for heavy conditions like you are talking about with about 50 pto hp and a 7ft blower.It takes a fair amount of power to run a blower, just be sure you have the ability to go slow enough to handle the snow load,in my case I have creeper gears to accomplish this.You must be able to go really slow when you have lots of snow to move.If you go with hst you will be fine also.The blower will not go into and chop up ice so your fel will be of a great benefit to help with that problem.I guess the secret is to have enough power to handle the size blower you choose and the correct back up speed to handle the amount of snow you run into hst would be great for this,plus enough weight ,loaded tires for sure, to handle the chores you will do with fel., backhoe etc..I am 64 yrs old and have no problem with the blower on the back as the fel comes in soooo handy,my fel. never comes off.Others here can give you better advice for backhoe work as I don't have one,but your concern was about snow and I have dealt with that all my life.I also have a rear mounted 8ft snow plow that works really well for the small storms as it is so much faster.
Good luck and the best with your new home,
Herb,
I am in the Great Northwest (Oregon) - altitude just shy of 5000ft.
Thanks HEC for the words of advice. The tractor does have HST. You mentioned you have a "good gravel drive", I am presuming you mean well packed down. Unfortunately mine won't be well packed for some time. Do you see any problems with a new gravel driveway? I don't really like the sound of rocks rattling inside the blower.
Last year I used my Polaris Ranger with a snowblade on my paved driveway, but I couldn't use it much as there was no where left to plow the snow too. My trusty little honda snowblower helped, but it is too much work and will not handle any ice.
Thanks again,
Friver
/ Newbie concerned about snow #9
I'll chime in on the side of 50 hp and a rear blower. I have found that a rear blower will chew up whatever the highway plow builds up at the road - even alternate "crusty" layers from freeze-thaw cycles. The layers are not very thick so it all breaks up and the auger/impeller handle it just fine. If it's really deep, just go slower. For a gravel road, the bottom skids can be set to hold the blower off the ground a little. Or, if you have one gravel and one paved drive, I saw a rig with each skid on an eccentric with a lever - so each end of the blower could be quickly jacked up a little if needed. I find that at the beginning of the season some small stones get scraped up, but after the ground freezes the problem goes away. Rocks generally need to be 2" or bigger to hurt anything - and then its usually just a shear bolt on the auger chain drive.
/ Newbie concerned about snow #10
Friver ,I see no problem with a new gravel drive once it has frozen and is pretty flat , I am very careful for the first couple of storms,once things are well frozen up here where I live it usually stays frozen for the winter. I let a couple of inches of snow get well packed down and frozen and then it is easy going after that.My drive is pretty flat so I don't have a traction problem, my wife and I both drive all wheel drive cars so that helps also.I see no problem with the huge banks either as long as they are not solid ice, just go slower as mentioned above.My drive is well packed down with good gravel , but I groom it every year also so the weeds and grass don't creep up on me, and it just looks good.Go to a site called driveway groomer.com. as they have a very good and very inexpensive way to keep a drive looking good, or if you want to spend more DR has a very good one also.The blower and hst will be a perfect combination for those large storms as you get the snow out of the way and don't have to deal with it again. I pick up a few small rocks now and then but they don't really hurt anything as long as the chute is pointed in a safe direction. I use a plow for the smaller storms and it will dig out a rock or two once in awhile.
Good Luck,
Herb
Thanks for the info. We had our first snow yeaterday - just a dusting, but an early dusting. Still framing the Garage(toy barn), so getting nervous about finishing before the real stuff hits.
I dont expect to purchase tractor till I am sure I am going to have a place to keept it, but that is only about a month away. I had been talking with a Kubota dealer in town here and he came up with what seems to be some fairly decent numbers, but I havent pulled the plug yet. There is another Kubota dealer about half way between my home and my "2nd home" and this dealer also handles Woods equipment. I am talking with him now. After reading some of the posts on here, I thought it was worth looking at the Woods BH.
Now I am wondering if I should be looking at a Woods Snowblower instead of the Kubota.
I had to stretch to justify the B3030, so I just cant go for any more horsepower.
Friver
/ Newbie concerned about snow #12
Remember you can never have too much HP. It is all about travel speed since most tractors can handle large mowers or blowers if you go slow enough.
/ Newbie concerned about snow #13
Friver
Have you considered a "basic" tractor such as the B7800. It'll provide the same PTO HP as the B3030 for less $$$.
If you are looking at 5' blowers you will want 22.5 PTO HP at the least. I have a B7610 (18 PTO HP) with a 4' front blower and it works fine. The 4.5 hp per ft is the lowest I'd want to go. 5-5.5 hp per ft would be better, esp in deep, heavy snow.
Also keep in mind that larger tractors have larger blowers with bigger augers and wider shutes. That transmits into moving larger volumes of snow more quickly, which all takes lots of HP to do. The L series blowers are larger than the B series blowers, which are larger than the BX blowers.
/ Newbie concerned about snow #14
Herb
Hey Herb... nothing like product promotion! I assume you bought it... how do you like it?
Get ready, snow is coming!
Keith
Kubota B7610
/ Newbie concerned about snow #15
If you are still framing the toy house consider having at least an 8 foot high garage door for your tractor. That will eliminate the need to fold the ROPS and eliminate toy house damage when you don't fold the ROPS.
Weather has settled down a little, so framing is on. the "toybarn" will have 9ft garage doors, so I should be in great shape for avoiding damage to the overhead.
I have considered the B7800 and I am still considering it. My original thought was to go with the B3030 if I went Rear mount snowblower or to go with the B7800 if I went with the front mount. Equipped that way, they came in about the same price. I somewhat prefer the B3030 and it has - according to the brochure - 23 PTO HP. That may not be on the high side, but it sounds like it should be enough to run the blower.
I only have a couple of acres that I intend to use this on, and I typically buy something, take reasonable good care of it and hang on to it for a long time. I expect this to be my one and only tractor (or, to last for at least a loooonnnng time). I am still considering other accessories - Grapple, chipper, box scraper but will wait and talk with dealer about those.
Thanks for the help and I appreciate any advice.
Friver
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2022 EZ-GO ELITE...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
Grain Drill Hopper (A64127)
Grain Drill Hopper...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
