New XUV Arrived
/ New XUV Arrived #1
Kahuna
I picked up my new XUV late yesterday afternoon. I haven't had too much of a chance to drive it yet because is got so cold. Tuesday it was in the 70's, yesterday and today the high is in the 30's and in the 20's overnight.
I traded in an 06 HPX. I can tell it is quicker and definitly smoother on rough ground. It is still bouncy but not near as rough as the HPX. It sits higher, maybe steers just a hair better and starts quicker. Although the HPX started very well. You had to use the choke in cold weather first thing but once you started it for the day it was good to go.
The one thing I do notice is that it is quite a bit louder. The muffler on the HPX was under the bed. The XUV is directly in the rear. I also have the poly roof on this one which I can tell gives an added echo effect. I have heard some complain about the brakes on the XUV. I have had a new 05 HPX and a new 06 HPX and both had spongy brakes where you had to press hard. It will get better when you get a few hours on them. The XUV feels about the same. They are a little hard now but I'm sure they will get better as time goes by.
Was it a good trade, yes. Would I do it again, yes. Is it a vast improvement over the 06 HPX, no. The HPX is a very good, well built workhorse and not all that less of a machine than the XUV. I figure I am getting a better ride more than anything. The extra 5 mph, to me, is not all that noticable. However, you do get there a little faster. I'm not too sure about the single post hydraulic lift. That twin post on the HPX was sure nice. When I hit the gas the tires take a little spin out, the HPX wouldn't do that.
I will tell better once it warms up and I can take it through the rounds. I got the gas version with dump bed, bed liner, floor mats, bumper guard, horn, poly roof and deluxe lights which consist of taillights, blinkers, brake lights and 4 way flashers. The 2 inch receiver hitch is standard on the XUV.
/ New XUV Arrived #2
Congrats on the XUV. I love mine. Go get an oil filter asap since the manual calls for an oil change at 8 hours.
I never had a HPX so I can't compare the noise. I put one of those super thick rubber horse stall mats in the bed and on the floorboards. I noticed a big difference in noise after they were installed.
It will definitely spin out in gravel.
The single piston dump works fine.
The brakes seemed a little weak going down steep hills. It may just be my limited exposure to UTV braking. I was expecting car like braking. I will check the manual to see if the braking is adjustable.
One thing is sure, my neighbors with various model Mules are jealous of it's size, speed and especially the ground clearance.
/ New XUV Arrived #3
Awesome Kahuna.
I'm very happy with mine.
The takeoff, extra clearance, fuel injection and the independent rear suspension are all huge enhancements over the hpx imho.
My hpx was constantly getting hung on the skid plate on the rear diff.
Hpx was nice but not as offroad capable as the xuv.
The xuv old performs my rhino in mud~! :eek:
/ New XUV Arrived #4
We have had some cold weather move in on us also. Since I will not be using mine the rest of the week, I took my xuv back to the dealer today. The brakes just don't work like they did on my hpx. I can't even get them to lock up on gravel. It took my running into something in my shed 3 times before I figured out the brakes were not right. Hopefully I will get it back Monday or Tuesday. JC
/ New XUV Arrived #5
Yeah I remember on my HPX I had to STAND on the brake to hold it on a hill but it loosened up pretty quick. It was the paint on the pedal or something that needed to be worn off though and not something else.
/ New XUV Arrived #6
There is a preservative applied to the brake pads to keep them from rusting during shipping / storage...
This coating needs to be burnished off - and should be done by the dealer as part of the required PDI / Set-Up.
These are four wheel, outboard, hydraulic disc brakes - if they don't almost throw you out of the seat during a full speed stop - something needs to be corrected. We had this same issue when the HPX first came out, (which is understandable as it was a brand new model, with brakes like never before on a Gator) but I don't know why we are having it again...
/ New XUV Arrived #7
No I mean the pedal was hard to depress NOT an issue with pads of any sort.
/ New XUV Arrived #8
Maybe something got skipped on mine during dealer prep. The spring on the parking brake was also very loose and rattles. JC
/ New XUV Arrived #9
the xuv is a new utv and this is the first year your gonna have to find the bugs i'm sure there will probably be more . there is always bugs with the first year anything to come out.
/ New XUV Arrived #10
This is kinda wierd?! The machine should not sit at a dealer for more than 6-9 months or so, but its very concievable that many owners may let the machine sit without using it for months on end... so are the breaks going to cease up on them? Not being critical, but curious...? We can get 7 lines of utility vehicals and I've never heard of anything like this.
/ New XUV Arrived #11
The preservative would be more to protect the brake parts before assembly so they don't rust on the way to JD, or while waiting to be installed on the line. Keeping them from rusting on the dealer lot is a bonus. I'm sure every mfg does this to some extent. I've heard this complaint on many disk brake vehicles that are not driven hard when first put into use.
Try doing a brake burnishing like on a car with new pads. Do 6-8 hard stops from full speed to get things really hot. Then, drive around 5-10 minutes with no brake usage to cool them down. I bet it makes a world of difference. That should seat the pads and remove and glazing that might have occured. It should be a one time thing. Or, could be required every once in a while if the machine is putzed around on exclusively.
/ New XUV Arrived #12
Especially if they took the slow boat to get here. They use some nasty coatings on parts to prevent corrosion while in that salt air environment.
/ New XUV Arrived
I know there has been soome discussion on previous threads about the deluxe light kit being backordered on the XUV. When I bought my XUV a couple weeks ago the dealers computer said to expect shipment in October. The light kit arrived today.
There has also been some discussion about the XUV brakes. Hit them hard a few times at top speeds. I have less than 2 hours and they are getting noticeably better already. That is what I had to do to both HPX's also. They eventually got to the point where it seemed like I had power brakes.
/ New XUV Arrived #14
I picked my XUV up two weeks ago, and ordered the deluxe lights the day after I brought it home. They came in 6 days after I ordered them. When you go to install them, the instructions have seperate pictures and directions for the XUV and HPX. Obviously they just had to re-number some of the components.
The only thing I don't like about the kit is the back of the taillights are pretty exposed...wires and all. Looks like if you were going to be doing a lot of trail riding thru brush, you would want to fab some type of deflector/shield. I was a little surprised that the brackets weren't very heavy-duty either. You could easily bend them by hand.
/ New XUV Arrived #15
I agree 100%. Its an excellent kit except the rear lights. I didn't put them on my xuv. I bent them to the point of no return on my 06 hpx. They should be recessed in the fenders~!
/ New XUV Arrived
The dealer is going to install the lights as agreed when I made the purchase. I have had the tail lights on an 05 and 06 Gator so I know how how easy they are to get snagged. That is the biggest drawback I have to the tail lights.
I was hoping they would come out with a better design for the XUV but since they are using the same bed I supposed they kept the same lights to keep the cost down (or the profit margin up). I also had the CX Gator which is the small version. The tail lights on it were actually designed into the bed and looked very sleek but it was a plastic bed.
I bent the tail lights on my 05 HPX so many times it never would go back straight. I was more careful with the 06 HPX and will be careful with this one. The easiest way to keep them good is to stay off the narrow 4 wheeler trails. The first thing you know is that you get next to a tree and there it goes. The light stays intact but the bracket gets turned about 90 degrees and light is pointing to side instead of to the rear. I just bend it back straight as best I can. I even bent them once backing out of the shed when the door was not opened all the way. I truly believe the tail lights should be standard equipment anyway. Then perhaps they would have a better system.
/ New XUV Arrived #17
Has anyone tried mounting tail lights on the vertical portion of the ROPS or deluxe cab frame? The deluxe cab frame has brackets already welded in place at the top of the rear windshield opening. They are high off the ground, but very well protected.
/ New XUV Arrived #18
I've thought about that on my HPX and actually bought all of the stuff needed to do it but never got around to it. It is a perfect location and I'm sure they would be well protected. I do have some extra lights I mounted myself under the roll bar for night drives and they are very well protected. While mowing a hit one with a branch somehow while going under a tree, I fixed it this spring. Total cost of replacement 11 dollars and 10 minutes. 5 of those minutes was spent looking for a crimp.
/ New XUV Arrived #19
I just got back from my longest XUV ride to date...about three miles on some dirt/gravel roads. I noticed a clicking noise when I got up to about three quarter speed...Can't seem to find what it is, but it is definetely coming from the front-end. I've only got 3 hrs of drive time so far, but this was the first I've heard it.
I engaged the on-demand four wheel drive for the first time today, before my ride, but I disengaged before heading out down the road. I'm just wandering if something in the front differential isn't causing it.
Anybody else experience/hear of this?
Thanks.
/ New XUV Arrived #20
Just ordered my XUV yesterday. 620i in olive/black with lots of extras. They said it won't be here til May 25. They are getting lots of orders.
-brian
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
John Deere RO764 (A60463)
John Deere RO764...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
