New Welder
/ New Welder
I bet she turns around and says: "hey, didnt I just see that welder over there?"
Generally she doesn't pay to much attention to what's in the shop. She just heads to the roll a way when she wants a crescent wrench to drive a nail, or beat on something else.:rolleyes:
Hey Mark how much OCV does this PowerArc 200 put out? I didn't get a manual with it, checked the website to download one, but couldn't find it.
/ New Welder #23
Enough to give you a good tingle... 70V.
Yes, I need to finish the manuals for this even though its fairly straight forward. Typically the Chinglish one in the box for this one is sufficient for this as there isn't much to it, but then if you didn't get one...
/ New Welder
Yeah I kind of figured it was too straight forward to waste paper on:thumbsup:. I was just curious as to how many OCV it produced. Especially after talking about voltage on the thread about 7018 AC.
Thanks!
/ New Welder #25
How easy is it to accidentally touch that 6010 port on the front? I assume both are hot when the welder is on. I know my old Sears has a couple of ports but you couldn't stick a finger in them and there's no exposed metal for something to accidentally touch.
/ New Welder #26
Something tells me that if that little Everlast was gray she wouldn't even realize it was a welder with all those big ones around it. Is that why you bought it, figuring it would be too small to be noticed? :)
/ New Welder #27
i saw a cutting torch on a job once, not sure but it may have been a 'harris' brand... anyway, it had a hammer head built into the barrel opposite the cutting tip.
we gave it to the carpenters and then made fun of them for the next 2 years :D:laughing::laughing::laughing:
/ New Welder #28
If a person is feeling pretty stupid someday, its pretty easy to do, if he/she tries. :) Mind you, you need to aim directly for it.:laughing: and you need to complete the circuit by grabbing hold of the work clamp or have your, moist wet body in direct contact with the ground. In reality its not any more dangerous than shoving an electrode into the holder. But this type thing has been around for years:
/ New Welder
The ground lead goes there, so I don't know if it's an issue.
No I bought it for the Hot Start option, and to take a little load off my Dynasty. Just soon leave the Dynasty for a dedicated Tig welder. Which this worked out perfectly, the PowerArc 200 welds circles around that $6,000.00 Dynasty on SMAW!
/ New Welder
That is a classic. :laughing::laughing::laughing:
/ New Welder #31
Yeah, that's right. I was thinking in terms of completing the circuit, and wasn't thinking about the fact it is the negative terminal. You'd need to hold the stinger end then...:confused2:
/ New Welder #32
Mark,
Am I reading your website correctly that the 200 and 205 will do both Mig and stick?
/ New Welder #33
Power I-MIG 200? Yes. You are reading that correctly and if you use a 17V or similar torch DC tig. Plus it has arc force/Inductance control for MIG. Built in post flow. Stepless control of both Voltage and wire speed. And it has a form of synergic control, which keeps you from welding terribly at almost any voltage. Heavy Duty cast aluminum pwm controlled wire feed. Deluxe Binzel mig gun. 4 or 8" drive roll without need for special adapters. Also it is spool gun ready
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
