New Welder
/ New Welder #31
The ground lead goes there, so I don't know if it's an issue.
No I bought it for the Hot Start option, and to take a little load off my Dynasty. Just soon leave the Dynasty for a dedicated Tig welder. Which this worked out perfectly, the PowerArc 200 welds circles around that $6,000.00 Dynasty on SMAW!
Yeah, that's right. I was thinking in terms of completing the circuit, and wasn't thinking about the fact it is the negative terminal. You'd need to hold the stinger end then...:confused2:
/ New Welder #32
Mark,
Am I reading your website correctly that the 200 and 205 will do both Mig and stick?
/ New Welder #33
Power I-MIG 200? Yes. You are reading that correctly and if you use a 17V or similar torch DC tig. Plus it has arc force/Inductance control for MIG. Built in post flow. Stepless control of both Voltage and wire speed. And it has a form of synergic control, which keeps you from welding terribly at almost any voltage. Heavy Duty cast aluminum pwm controlled wire feed. Deluxe Binzel mig gun. 4 or 8" drive roll without need for special adapters. Also it is spool gun ready
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2014 Chevrolet Silverado (A60352)
2014 Chevrolet...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2008 BMW 535xi AWD Sedan (A59231)
2008 BMW 535xi AWD...
M998 (A55852)
M998 (A55852)
