New water well
/ New water well #41
Reading all the replys has me glad to have my well 65 ft deep with the pump hung at 55 feet. 20+ gpm no minerals, and crystal clear
/ New water well
That's really good. Water here in the Blue Ridge is everywhere... springs, creeks, runs, etc. Well water is hit and miss. When we had our cabin up at 3,000ft, we had great water at 450ft; the two neighbors near me had nothing but 700ft empty holes. :confused3:
/ New water well #43
Just curious. How do well drillers price a well in different parts of the country? I expected to pay by the foot last year and hope we hit reasonable water, but my driller gave me a package quote guaranteeing minimum 5gpm including pump/motor, 120 tank, etc. The same company has drilled many hundreds or thousands of residential & Ag irrigation wells in the area over at least 5 decades.
/ New water well #44
Just had my first experience with drilling a new water well. Pretty amazing piece of equipment to watch. Took about 12 hours to hit 620 ft. According to my driller we have right at 4 gal/minute replenish rate, a 570ft head of water with the pump sitting at 585; this gives us an 800 gal reservoir in the well. 4 gal/min doesn't sound like a lot, but with reserve we should have more than enough for two people. We have a spring house as well on the property, but I don't have power to it yet.
We went a total of 610 ft. Well head is at 35ft, and pump set at 585 ft. With a 6inch casing this gives us about 800 gallons reserve at 3gpm replenish rate. More than adequate for a 4 bedroom/bath home. We put in a 30 amp 2 pole breaker for a new 220 volt Grundfos pump. I ran a line to a yard hydrant near the shop (250ft away) and a T to the house (about 100ft). Also put in a yard hydrant 6 ft from the well head for future use. All water lines are 1 inch blue poly. The entire process ran right at 12K finished including electric.
Different parts of the country have different terms but you have used a couple that I think I know what you are saying but would like clarification.
You state 570 head of water then you state well head is at 35 ft.
Everywhere I have ever been they talk about the "static water level" in a well and "dynamic water level" at a given rate (production rate). Doing the math from your other numbers, I think your term well head may very well be the same as static water level.
Setting the pump at the 585 ft depth is a lot of excess copper wire and drop pipe unless your dynamic level is way lower than the static level and needs to be that deep.
Always curious as to why a driller does a specific action. Is your well steel cased all the way or is the hole consolidated at some level and then they used a 4.5 inch PVC casing?
/ New water well
Well is cased 60ft with 6" pvc, not sure what schedule, but was about 1/4" thick. The same 60ft is also grouted in under pressure creating a concrete column around the pipe. The water level in the pipe is 35ft from the top. Around here they use the well as the reservoir, hence setting the pump at 585.
/ New water well #46
How long does it take them to drill through 410' of granite?
Here they went 760' and 4" casing to 460'. Mostly sand and clay took about 12 hours of actual drilling.
They were drilling for three days - about 20 hours of drilling and used a rotary drill (not a hammer type) then they came back and fracked it a week later - as I recall it was around $8/foot then fracking and pump install on top of that total around $6K at the time. The well guy contracted the driller so the exact $ breakdown between drilling and pump wasn't exact.
/ New water well
Finally getting in our new 400amp service from the road. The old line and pole near the house will come out. Also was finally able to get the old moonshine tanks out of the woods to the burn pile.
/ New water well #48
Direct cable burial electric service is allowed?
/ New water well
Yes... Short story the house system was 60 amps, the existing overhead wire was under rated for new 200 amp service, and the pole near the house was like 80 years old. So we made a deal to direct bury and I pay the upcharge. Got a new 400 amp service and new transformer being put in behind the shop.
/ New water well #50
Direct burial is not permitted in many parts of the USA!
Conduit only,.... for "Dig Safe".
/ New water well #52
I have a 4kv primary direct buried back to my house. It was done early 80’s. I dug the trench and back filled, the electric company provided the cable, transformer and pad as well as the secondary to the house from the transformer. All direct burial.
/ New water well #53
I too have a direct wire burial line that I did myself in 1984.
PVC has been required for all underground service in this area now for the last 30+ years.
/ New water well #54
Mine is direct bury, about 450 yards. 4 foot deep. Conduit under road, in the rocky area of the dig, but not everything. Conduit from transformer to house. At that time the power company paid for everything. Today, the customer pays.
/ New water well
Oh yeah you do....
/ New water well #56
I am waiting on my rural electric co-op now to run a new service. They'll direct bury 100ft from their existing pole on my property to the barn. The fee was $125. If it was to a residence it would have been no charge. Sounds like I'm fortunate.
/ New water well #57
You are. When I upgraded my service (200a to 400a) the power company required me to provide 3" conduit 5 feet below grade. They inspected the trench first, then after backfill they pulled the new wire.
/ New water well #58
You definitely are- my 175’ for a 400amp service from the junction box to my shop (including a transformer install at roughly 50’ from meter base) was roughly $6k. I did the ditching and backfill myself as well as the conduit sweeps at the meter and transformer.
/ New water well #59
Some states are better. I wonder what Texas with their power problems charge?
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
