New vs Old
/ New vs Old
Just an update. I guess my new loader must not be power down. I swapped quick connects no changes. I can lift the front of the tractor with the dump and curl functions but not with straight down. Guess I will just use the curl or dump if I get stuck.
/ New vs Old #22
Look at your cylinders. If they are retracted that is all the lift you can get.
Curl the bucket down, then try and lift the front.
/ New vs Old #23
I can't lift mine that way either. As Egon said, they can only retract so far.
/ New vs Old #24
Curled down first then lowered the loader, lifted the front. :thumbsup:
/ New vs Old #25
I'll tell you one thing, if I ever buy another tractor it will be used and the engine rating will be no higher than Tier II.
2017 Mack Semi (A64047)
2017 Mack Semi...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
PT 4 Cylinder Power Unit (A64127)
PT 4 Cylinder...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A59914)
2007 VOLVO VHD...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
