New vs Old
/ New vs Old
Just an update. I guess my new loader must not be power down. I swapped quick connects no changes. I can lift the front of the tractor with the dump and curl functions but not with straight down. Guess I will just use the curl or dump if I get stuck.
/ New vs Old #22
Look at your cylinders. If they are retracted that is all the lift you can get.
Curl the bucket down, then try and lift the front.
/ New vs Old #23
I can't lift mine that way either. As Egon said, they can only retract so far.
/ New vs Old #24
Curled down first then lowered the loader, lifted the front. :thumbsup:
/ New vs Old #25
I'll tell you one thing, if I ever buy another tractor it will be used and the engine rating will be no higher than Tier II.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63118)
2023 Top Air ATV...
2015 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2015 REITNOUER...
SANDBAG ATTACHMENT (A63569)
SANDBAG ATTACHMENT...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
