New vs Old
/ New vs Old
Just an update. I guess my new loader must not be power down. I swapped quick connects no changes. I can lift the front of the tractor with the dump and curl functions but not with straight down. Guess I will just use the curl or dump if I get stuck.
/ New vs Old #22
Look at your cylinders. If they are retracted that is all the lift you can get.
Curl the bucket down, then try and lift the front.
/ New vs Old #23
I can't lift mine that way either. As Egon said, they can only retract so far.
/ New vs Old #24
Curled down first then lowered the loader, lifted the front. :thumbsup:
/ New vs Old #25
I'll tell you one thing, if I ever buy another tractor it will be used and the engine rating will be no higher than Tier II.
Sun Burst Box Blade (A64047)
Sun Burst Box...
SDLD25 Crawler Dumper (A64047)
SDLD25 Crawler...
Craftsman T140 Lawn Mower (A64047)
Craftsman T140...
2023 Hustler X-One Zero Turn (A63116)
2023 Hustler X-One...
2017 New Holland T.4 100 w/ Loader (A64047)
2017 New Holland...
(4) Trail Finder S2 215/75R/17 Tires and Rims (A64047)
(4) Trail Finder...
