New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #131
Mrmikey in your experience in the business did you ever "put together" a s/a medium dump for a smaller, mostly owner-oporator operation that had widely varied duties where one day he's running light mulch or dry topsoil and needs the volume, and a couple of days later needs 6-8 tons of stone or sand?
Typically he's going know his truck and load it according to the material (weight) and doesn't want to see a big fine or damage his equipment.
Which of the recommendations on the chart would be the one(s) to "bend" or would it be a combination of this.
Your knowledge and experience have been a great help imho for/to this thread and for anyone following it.👍
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #132
No, 'fraid not. I worked in the welding shop of a provincial DOT mechanical facility for 25± years then went to pencil pushing for 5±, same facility. At first the trucks were pretty much a 50/50 blend of single axle and tandems, in later years they went to tandems exclusively as they were more versatile for the cost. The trucks were used for salt and/or sand spreading in the winter and shouldering or ditching in the summer with the occasional road washout and asphalt repair thrown in. Saying that, the majority of the product has close to the same density/weight not like cotton balls and lead :).
They changed to using spreader inserts in the winter which were more rearward mounted so we had to change the positioning of the bodies to find the best compromise of seasonal use as far as weight distribution was concerned. Then you had to take account of the weight of the plow and wing gear which was biased to the right. Add into that mix the weight of brine carried for pre-wet.
All of this while not going over the maximum GVWR as well as the front and rear GAWR
You are 100% correct. But that is a situation where he breaks it he has to pay for the repairs, it's out of his pocket. I'll say no more on the subject except the common saying was a machine gets greased twice in it's life time....first and last. I gave up complaining at the end...it made no difference.
As for which specs to 'bend'. I can't really answer that, the only true way is to scale the truck with a load of whatever the most common product would be carried and move the body to get the best load specs which I've done.... and it's a pia. Only salvation in my case once you did it, you didn't have to do it again as the trucks were close to identical. Now days there's software that once you have the body weight, axle weights and dimensions it'll do the figurin' for you.
Moving one affects others. Lengthen the overhang, the rear axle gets heavier and the front lightens up. Same situation, you could load the body front heavy and it may even out to a certain extent.
Thank you, I appreciate the compliment.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #133
Beamboy should be able to handle that, @Hay Dude if you have current weights per axle, the current wheelbase, the amounts you want to try shortening it by and an approximate weight of a box I can probably get close on there.
Aaron Z
I have a 14ft bed on 12-6’ of frame. I don’t particularly like how much it sticks off. It makes it hard to pull a trailer and not cut into it. The axel center is 9ft from the cab. View attachment 785811
Are you sure thats only 18” of overhang? Looks like 2-3’ of overhang
I don’t have current weight per axle (if you mean unloaded with body installed).
The rear is a 30,000lb rear
The front is a 16,000lb front
The GVWR is 41,780
Wheelbase is listed as 465cm or 183”.
My previous truck was very similar, but only 33,000GVWR with a 12K front and 21K rear. Only frame reinforcement was an overlay “L” from the back of the cab to the rear. Empty it was 17,000lbs. It had a high wall 12’ dump box. I loaded it with 10 tons gravel a few times. I know it was overloaded, but it handled the load pretty easily.
This truck is built much heavier, so if I’m only looking at a 11’ box (maybe 12’) I don’t expect to be overloaded. I mean the rear axle alone is rated 9,000lbs heavier. The front axle is rated 4,000lbs heavier. The frame is doubled the entire length. The spring packs are much bigger.
I’m more concerned about the frame being modified and repaired properly and the axle being moved forward to the correct position.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #136
It’s 2ft of overhang because the inside of the bed is 14’ which makes the outside a little more plus the couple inch gap between the cab.
OK that’s more like it.
I won’t have 2’ of overhang, probably more like 18”.
I just talked to a guy who runs a lot of state salt trucks and he said that should be fine for an 11’ body, but I think 12’ might not happen.
The 10” spacing from the cab and 18” off a 12’ frame means frame now has 10’-2” of usable frame. 11’ bed would have about 12” of overhang. 12’ bed would leave about 24” of overhang. I don’t know how much it’ll affect towing.
I don’t see many 11’ dump bodies for sale. 10’ much more common.
A few update pics. Truck frame is now sandblasted, primed & painted. It looks better, but reminds me of a kid with bad acne. The scars are still there. :oops:
We cleaned all the rust jacking out we could reach. You’ll also notice we removed the exhaust stack. I found some 5” exhaust pipe and we are going to try to fab-up an exhaust pipe. The stack is still good, but the bottom where water collects was toast.
I paid $18/foot for exhaust pipe and $24 for a 5” coupler. Not cheap.
Anyway, things are progressing, but slowly.
Still looking for high sided 10-11’ bed, then we will know how to handle the end of the frame and moving the axle.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #139
Not scars...character :).
What about just going with a turn down? If you can get away from a vertical stack it my prevent problems with a cab shield depending on the type and style of body you find.
You're lucky, there's no DPF or SCR to worry about. The newer trucks I was working on had $15-20K of exhaust crap behind the cab and enough structure to support a car bridge holding it up. Not only that, since it was an engineered system you couldn't move a thing from factory...nothing.
You get the frame flanges flattened down some? They don't look as angled up as they were.
......then we will know how to handle the end of the frame and moving the axle
Gonna have to watch your drive line angles too
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #140
Not knowing any better, could Hay Dude cut front off a 10ft box and extend it to 11ft? What would that entail? I have no experience with dump trucks other than buying gravel and having it dumped and sometimes tailgate spread. Jon
2005 Ford F150 XL Triton (A50120)
2005 Ford F150 XL...
Wacker Neuson ST31 (A50120)
Wacker Neuson ST31...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
