New trailer build
/ New trailer build #42
One thing I like to do is get some stainless steel bolts (usually 1/4-20 1 1/4") and weld them to the steel frame near where all the lights and brakes are going to be plus one near the tongue. They make for a ground that will never fail. I do run ground wires as well but having grounding studs that will never rust makes for an easier install and trubleshooting down the road.
I like that, great tip!
/ New trailer build
Put fenders on this morning
/ New trailer build #46
Looks better than a factory bought one. I bet the paint will last longer than those. Great Job.Ive been building trailers (light) for years but all I ever had was used and discarded metal. I always wanted to be able to see what one of mine would have looked like if I had the materials.
Im wondering on the lights? LED? and how they should old up to the bouncing and jarring. ?
Again Great Job..
/ New trailer build
Again Great Job..
Thanks
Three coats of paint, then finish deck welding and then another coat. But it's a trailer and will get banged and chipped. Will probably need a touchup every year.
No just regular lights.
/ New trailer build
Got the deck metal on one side. The 3# expanded metal is tough to cut. Don't have Torch or plasma so had to cut with a zip disk. This deck is very stiff and doesn't go bong like diamond plate with every step.
/ New trailer build
Finished putting deck on this morning. That 3# expanded is definitely a pain to cut. Two 4 x 8 sheets completed the deck with almost zero waste.
Now the painting has to be finished. Looks like spraying will waste lots of paint. Lots of air to paint.
/ New trailer build #50
Nice work! Didn't see it mentioned, but where did you source the weld on 'D' ring tie downs?
Terry
/ New trailer build #52
Thanks. I should have seen that. Guess I'd better go post over on the 'Welding and Age' thread now...
Terry
/ New trailer build #53
Put some cardboard under it. Then you aren't wasting it, you are making nice designs on the cardboard. :)
Looking great, BTW!
/ New trailer build #54
Spray at a shalow angle, rather than straight on. If you look through the mesh at diferent angles, you can see that at shalow angles you can't see through as well. I figure that way will catch more paint. If they wern't welded down you could stack them and spray them together.
/ New trailer build #55
Is the expanded metal going to be strong enough to support a 3500 lb vehicle if parked between the cross braces?
Are you going to make cover plates for the inside of the fenders to prevent dirt, stones, mud etc form coming off the tires and hitting the towed vehicle?
What is the tag you have on the tongue in post 49?
Very nice build.
/ New trailer build #56
Terry, obviously I know nothing of your area's resources, but I found weld-on rings at my local steel supply (no NOT Homeless Despot :=) - it's Ram Steelco. They have a section of shelving on one side of the office with axles, fenders, couplers, etc, and a couple different sizes of tie-down rings - the weldable part is kind of a mini-version of the pieces I just bent with the "superjig" you helped me with (pre-heat thread)
Just a thought, if you haven't already looked at yours.
Or, if there's nothing local (I know, Canada shipping, PITA, etc)
D-Rings & D Ring Tie Downs: Trailer Tie Down Anchors & Weld On D Rings
Weld On Trailer D-Ring Curt Trailer Cargo Control J-705
Wholesale D Rings | Weld On D Rings
D-Ring Shackle - Weld-On Tie Down Anchor
Those were just part of the first page of a google search on weld-on tie down
Stick wit' me, I'll "learn ya some shlt" :D:D:D:D (BTW, didja get yer press jig fancied up yet? (OK, I'll quit now :rolleyes: ... Steve
/ New trailer build #57
[QUOTE="BukitCase;Stick wit' me, I'll "learn ya some shlt" :D:D:D:D (BTW, didja get yer press jig fancied up yet? (OK, I'll quit now :rolleyes: ... Steve[/QUOTE]
Dang. Kind of hoping you'd forgotten I said that. :). Thanks for the links. I enjoy noting the prices, deciding I can make them myself cheaper and ending up having the finished product costing 2 or 3 times more.
Terry
/ New trailer build
Very nice build.
My local metal supplier suggested the 3# as they supply quite a bit of it for car carriers. The clear span in the strong direction is only 20 inches and it's welded down every 8 to 10 inches. I'll know better when I load my 3500# tractor in a few weeks.
Haven't decided on the cover plates yet although I think I am leaning that way.
The tag is the serial number supplied by Department of motor vehicles which has to be verified in place on the trailer by the police before the trailer can be liscenced.
/ New trailer build #59
I figured that was what the tag was. Down here you have to completely build the trailer first then make an appointment to take it in for DMV inspectors to look at. They won't issue a tag until they inspect it and if they see something wrong they make you take it back home to fix then make another appt.
/ New trailer build #60
When in Canada, check Princess Auto. 3 in. Weld-On Tie-Down Anchor Ring | Princess Auto
HF even has some bolt-on that could be welded easy enough. 2 for $5! http://www.harborfreight.com/1-2-half-inch-forged-cargo-d-ring-96232.html
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2002 Hyster C330B Tandem Smooth Drum Roller (A61567)
2002 Hyster C330B...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Mower King...
2008 HINO 268 4X2 S/A ARMORED TRUCK (A59910)
2008 HINO 268 4X2...
JOHN DEERE 50P EXCAVATOR (A62129)
JOHN DEERE 50P...
UNUSED SDLANCH SDLE18P MINI EXCAVATOR (A62130)
UNUSED SDLANCH...
