New trailer build
/ New trailer build #52
Thanks. I should have seen that. Guess I'd better go post over on the 'Welding and Age' thread now...
Terry
/ New trailer build #53
Looks like spraying will waste lots of paint. Lots of air to paint.
Put some cardboard under it. Then you aren't wasting it, you are making nice designs on the cardboard. :)
Looking great, BTW!
/ New trailer build #54
Now the painting has to be finished. Looks like spraying will waste lots of paint.
Spray at a shalow angle, rather than straight on. If you look through the mesh at diferent angles, you can see that at shalow angles you can't see through as well. I figure that way will catch more paint. If they wern't welded down you could stack them and spray them together.
/ New trailer build #55
Finished putting deck on this morning. That 3# expanded is definitely a pain to cut. Two 4 x 8 sheets completed the deck with almost zero waste.
Now the painting has to be finished. Looks like spraying will waste lots of paint. Lots of air to paint.
Is the expanded metal going to be strong enough to support a 3500 lb vehicle if parked between the cross braces?
Are you going to make cover plates for the inside of the fenders to prevent dirt, stones, mud etc form coming off the tires and hitting the towed vehicle?
What is the tag you have on the tongue in post 49?
Very nice build.
/ New trailer build #56
Terry, obviously I know nothing of your area's resources, but I found weld-on rings at my local steel supply (no NOT Homeless Despot :=) - it's Ram Steelco. They have a section of shelving on one side of the office with axles, fenders, couplers, etc, and a couple different sizes of tie-down rings - the weldable part is kind of a mini-version of the pieces I just bent with the "superjig" you helped me with (pre-heat thread)
Just a thought, if you haven't already looked at yours.
Or, if there's nothing local (I know, Canada shipping, PITA, etc)
D-Rings & D Ring Tie Downs: Trailer Tie Down Anchors & Weld On D Rings
Weld On Trailer D-Ring Curt Trailer Cargo Control J-705
Wholesale D Rings | Weld On D Rings
D-Ring Shackle - Weld-On Tie Down Anchor
Those were just part of the first page of a google search on weld-on tie down
Stick wit' me, I'll "learn ya some shlt" :D:D:D:D (BTW, didja get yer press jig fancied up yet? (OK, I'll quit now :rolleyes: ... Steve
/ New trailer build #57
[QUOTE="BukitCase;Stick wit' me, I'll "learn ya some shlt" :D:D:D:D (BTW, didja get yer press jig fancied up yet? (OK, I'll quit now :rolleyes: ... Steve[/QUOTE]
Dang. Kind of hoping you'd forgotten I said that. :). Thanks for the links. I enjoy noting the prices, deciding I can make them myself cheaper and ending up having the finished product costing 2 or 3 times more.
Terry
/ New trailer build
Very nice build.
My local metal supplier suggested the 3# as they supply quite a bit of it for car carriers. The clear span in the strong direction is only 20 inches and it's welded down every 8 to 10 inches. I'll know better when I load my 3500# tractor in a few weeks.
Haven't decided on the cover plates yet although I think I am leaning that way.
The tag is the serial number supplied by Department of motor vehicles which has to be verified in place on the trailer by the police before the trailer can be liscenced.
/ New trailer build #59
I figured that was what the tag was. Down here you have to completely build the trailer first then make an appointment to take it in for DMV inspectors to look at. They won't issue a tag until they inspect it and if they see something wrong they make you take it back home to fix then make another appt.
/ New trailer build #60
When in Canada, check Princess Auto. 3 in. Weld-On Tie-Down Anchor Ring | Princess Auto
HF even has some bolt-on that could be welded easy enough. 2 for $5! http://www.harborfreight.com/1-2-half-inch-forged-cargo-d-ring-96232.html
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
