New tractor filled tires?
/ New tractor filled tires? #41
So you recommend he drives *his tractor several hundred miles one way* to a dealer that installs BJ? I live in SC TN. The closest rimguard dealer is south KY, about 150 miles - one way.
In short: Get Real; this isn't the north.
ETA: I think RG is the shiznit. If I could get it here, there would be no contest. But you guys in the north where it's available on every tractor corner need to get real: Rimguard doesn't operate nor sell down here. Now, if they would only grow up and start selling 55 gallon barrels to any Tom, Dick and Harry (read Amazon/Ebay/whatever) boom, I'd be all over that stuff. but as it is, it's not worth a +150 miles trip one way.
Why would you bring the whole tractor to have something done to the tires? But then, why would anybody go to a tractor dealer to have tires worked on instead of a local tire shop?
/ New tractor filled tires? #42
In my case it comes down to weight. We have 4 tractors but only one has a loader on it. That’s the one with 16.9-30’s with 100 gallons of fluid. Then add the weight of the tire, rim, center, and 2 wheel weights I have no way to handle it since that’s the only tractor we have with a loader. 2 of our other tractors have loaded rear tires as well but I don’t think I’d want to try and wrestle them either.
I agree with you on taking it to a local tire shop. I called four tire shops when looking for rear tires, never even thought about calling a dealer.
/ New tractor filled tires? #43
for a field tractor or loader tractor i might consider loading the tires but likely not, to have on removed or remove one yourself is a lot of work not to mention costly then you have lost the fluid or have to have it pumped out before you can repair the tire or tube if you are running liquid in the tube vs tire.
One flat and its a mess to deal with no matter what fluid you use - If my tractor was not being used in or aroudn trees or stobs or thorns or debris that could puncture or rip off a valve stem ( on a tube especially ) this is a real pain in the rear.
I would use weights over fluid EVERY time or a ballast, I hate flats!!! so anything that makes dealing with them more complicated/time consuming/more costly is out of the question.
/ New tractor filled tires? #44
yep, 2- 300 pound weights each side
Kioti NX cab with R4 and Rimguard. Good traction and toughness for woods. Still need chains for ice and mud.
Yep, R4’s don’t really like mud.
/ New tractor filled tires? #46
there is also bioballast, not sure on their distribution area, but its what most shops have in the west.
i would get them filled. I cant imagine loader work on my AC without filled tires, it was a bit light on the butt when we picked 500 lbs out of my truck with a chain on the loader, with the filled rears. i bet a full scoop of damp soil would have been tippy without the fill.
/ New tractor filled tires? #47
Weights or WW fluid would be my choices in a Gulf State for o'all the least mess/hassle. Less rust possible with nitrogen fill.
Weights work here .. where/when I don't have Rim Guard in R4s.
Set 'em wide & load 'em if you can. The cab helps grip plenty and you can do either of the above, as in 'some is better than none.'
Use what's easy to do, and to keep up with if you're the most security-minded .. like me. :2cents:
/ New tractor filled tires? #48
I’m sorry, did you just recommend filling tractor tires with nitrogen?
/ New tractor filled tires? #49
Nitrogen in tires makes cars & truck go faster while getting better mileage. No arguing with 'high tech', you know. :rolleyes: And no apology needed.
Admitting I use the cheaper 78% nitrogen blend with 21% oxygen boost and proprietary component matrix infused into the product. :D
Of course both these recommendations are better than air, and cheaper than pure maple syrup. btw, I hear ketchup is no longer a top choice for ballast.
'Dead serious' shouldn't exclusive to the dead.
/ New tractor filled tires? #50
how about helium maybe tractors can fly?
/ New tractor filled tires? #51
Nitrogen vs plain air gives a more consistent pressure in car tires, not that it's necessarily noticeable to most people. The reason is that normal air has water vapor in it; when the water vapor condenses, there's more contraction of the volume than that of an ideal gas undergoing the same temperature change - and similar in the other direction if there's actually liquid water being added to a tire (idk how, maybe someone didn't drain the air tank?) when the temperature goes up, because liquid water turns to a much larger volume of steam when the tire heats up. As I said, though, this really matters the most to racers, but it's a selling point, possibly slightly more legitimate than gold connectors for your fiber optic cables...
For tractors... ridiculous.
Especially when you're filling the tire with a bunch of water-based liquid!
/ New tractor filled tires? #56
true we should just leave them airless - wait i did, i have a set of those ;-)
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
John Deere 608C (A64119)
John Deere 608C...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
UNUSED ATSPOWER PLASMA CUTTER (A64281)
UNUSED ATSPOWER...
