New tractor advice please!!
/ New tractor advice please!! #1
tacotory
Bend
none
Hello. New to the forum. Really appreciate the great info here.
I am hoping for a bit of advice. I am in the market for a tractor.
I am looking for a used unit in the $25k-ish or less range. I don't care if it is an older unit, but would like something with low hours so I am not having to spend $$ to keep it going.
We are buying 11 acres and I need a tractor to take care of the property and to do light farming work. Initially I will need to disc/ harrow, then plant, and later mow the acreage. Also misc farm activities- remove old fence, build new fence, grade driveways, move snow, maintain manure, etc. In the future, I may want to hay the property and would like the ability to run a rake and square baler.
I am thinking a 4x4 tractor in the 60-80hp range with a loader on it.
Growing up on a hay farm, we had Ford tractors- 6600 2wd, 8600 2wd, and TW15 4wd. We had great luck with all these machines. I am thinking something in the size of our old 6600 would be a good fit for our new property- not too big to be useful for misc tasks, but big enough to have some muscle and run a baler in the future.
Any advice on brands to consider, models, and year ranges would be great.
There are a couple of 5000 series JD tractors (5210, 5420) for sale locally that look interesting, but had read a few posts by folks that weren't too happy with the 5k series and recommended going with older units... Also a NH Workmaster 55 local. A little smaller in the HP range, but in the ballpark...
At any rate, any advice would be amazing. Thanks in advance for your thoughts!!
/ New tractor advice please!! #2
Peruse regularly craigslist and tractorhouse.com.
JD,MF,Kubota In any of these brands you should be able to find a 60-70 HP tractor.
Welcome to the site.
Edit: What do you consider low hours?
Thank you for the advice. Any recommended or ill-advised series to watch for with the above mentioned brands?
Would like to see sub 1000 hrs. Maybe 1500 hrs if well cared for.
/ New tractor advice please!! #4
Can't really say that I have heard of any ill-advised models. My MF's have been really good. None of them however fit your size or budget. If you saw a 4608 MF I wouldn't be afraid to look at it.
A short search of Bend OR craigs and I saw this JD: John Deere 542 Tractor with Loader
A little above your 25k but it looks like a decent deal from a lap-top anyway. And he may negotiate down a few hundred too?? That would be perfect for the small farming you describe. Though maybe a bit cumbersome if you have small jobs in tight areas. Worth a look and call.
2015 MACK PINNACLE (A63569)
2015 MACK PINNACLE...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
Arrow Quip 10' Corral Panel X 5 (A64047)
Arrow Quip 10'...
John Deere 4520 (A60462)
John Deere 4520...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
