new to welding
/ new to welding #21
My very, very brief assessment was a fair rule of thumb for the complete newbie just starting out. I realize it is an oversimplification of a complex subject. I did recommend expert training on rod selection etc precisely for this reason.
Welding Rods Applications
I am sure you have more welding experience than me, so don't be shy with the advice. I am sure the OP would appreciate all the info and tips he can get :)
I'm new to welding my self, here are couple threads that might be interesting to read.
http://www.tractorbynet.com/forums/welding/211678-6013-break-test.html
http://www.tractorbynet.com/forums/welding/211904-7018-break-test.html
/ new to welding #23
The position you have to weld in will also determine your rod selection. If you are on your back (sometimes can not be helped) you will prefer a 60 series if weld allows...:laughing:
/ new to welding #25
Gizmo,
It takes BIG man (or woman) to admit that. You'd be a dream customer. I don't know very much either, and I keep learning, even though I've been welding for over 30 years of my 40 year life, been to school on welding (and graduated, run my own business on the side, and worked for and with others welding. It really only means very little, and means my welding experience is defined by that. Outside of my experience, I get uncomfortable...Don't even mention electron beam welding, or sub arc, because I just never have done it. I can say honestly that I am just beginning to scratch the surface good. A good dose of humility is good for us all. Welders by and large get the big head real easy. I know mine has from time to time. Any one experience the same thing?
/ new to welding #26
Gizmo,
Welding for GM for 30 years I was spoilled with the nicest Miller TIG welders and unlimitted supply of inert gasses & tungsten. Only relied on stick & gas torches for welding at home. Mainly we used to be able to "carry in" home projects for welds with a supervisor pass so even that was only for heavy duty (Uncarryable) welding but that ended in the 90's. Was retired 12/2009 and recently picked up a Hobart 190 for thin stock & aluminum work. Talk about a reverse learning curve...
Humbling! Learning with new technology is very Humbling (my cell phone:confused2:).
Glad they have come as far as they have with spool guns for pushing aluminum wire, etc. Last time I MIG welded was for Chryslers in late 70's before layoff & GM.
Glad I joined here to the wealth of information and support! Thanks All!:thumbsup:
Gary
/ new to welding
wow !!
rootpasses, skull cap, arc blow, ?? i`m lost.
i like the idea of the wagon for a cart there would be a lot of room to carry acc`s.
i`ll do the miller book. the torch brings up something i`d not thought about, what would be a good torch to get one better than a starter , not the cheaspest
but a keeper.
can you use propane instead, & are all the goggles the same one any better than the other. i`ll be ordering helment, tools, gloves, apron etc. today.
no one mentioned boots, do you need any special soles. ?
thank you to all for your advice & suggestions.
candyman
/ new to welding #28
Gizmo,
Gary
Male and not very big 5' 7":D Thanks, to both.
Been welding for more than 40 years (not for a living), taught by my father. First weld job was building up bulldozer pads on a D8, sure taught me how to run a bead.
I have never used a MIG or TIG and at this point in time don't think I ever will.
wow !!
but a keeper.
candyman
I'd scratch the propane idea. Keep in mind, the more expensive stuff you buy, welder, oxygen acetylene torch and gauges will probably last a life time. What has been mentioned so far should get you started. I never got caught up in all the clothes deal but then again I never welded for a living, tee shirt, sneakers whatever I have on works for me. You'll get accustom to the burns and sparks. I would say by far the one thing you don't want to skimp on is eye protection. Weld flash/burns are not fun or funny, been there done that, it can and will blind you.
/ new to welding
gizmo,
what are weld flash burns. is one helment better.why scratch propane.
cm
/ new to welding #30
cm
Easy, you cant weld with it. A stick welder and oxy acet torch are the perfect combo. Stick welder for welding anything over say 1/8. Torch for cutting, bending, brazing, and welding thin stuff. With propane, you can only cut and bend.
/ new to welding #31
gizmo,
cm
I have always used a #10 lens for welding and never had an issue. Google "Welding Flash".
Propane, IMO, is a PITA. Yeah I know that explains a lot but I am sure others will add. As did deereman75.
/ new to welding #32
gizmo,
cm
Weld flash is when the arc is exposed to bare eyes. It could be a auto helmet that didn't darken on time or a touch when the helmet is not in use. Pros can get it from reflections in the shop or others welding. You'll see spots and have scratchy eyes for a few days. It can cause permanent damage.
Burns are well...burns. I wear Carhartt overalls for their thickness and flat front (prevents sparks from getting where you really don't want them). Pros wear leather aprons or jackets for the same reason.
Recommended shoes are steel toes, over the ankles, heavy leather. They will keep the sparks off your ankles. Special soles are not really necessary unless you plan to weld while standing in water.
I once cut a heavy beam on a sharp angle and it let go before I was fully prepared. It impaled my foot through a light shoe. Never again - it has been steel toes and leather since then. Yeah...close the barn door after the horse got out.
Propane is of limited use. The big box stores like Lowe's and Home Depot have medium-duty torch sets. You will be shocked at the price but they have to be made well for safety's sake. Then there is the killer - the price of the O/A bottles. The O/A set-up is something to look for on Craigslist unless you have a large budget.
After years of O/A use I went with a plasma cutter. Talk about luxury. But that is a high dollar issue. O/A is more versatile if you can only have one. Having both sure is nice.
As far as the helmet goes, you'll end up getting a good one eventually so might as well start off with it so you don't have a half dozen or so helmets in storage (don't ask). Plan to spend over $200 for a Miller, Jackson, Lincoln if you decide to go for the better ones. Auto-dark is a must for beginners like me.
Don't believe the crap from ShieldArc about being new. He is (was) a pro and has excellent advice. We all learn new things so maybe that is what he means.
What is your budget for all of this? That may make deciding what is essential more realistic. Right now you are probably looking at $2K - $3K just to get started if you follow most of the recommendations.
/ new to welding #33
Righto. 6010 and 6011 are fast freeze rods--what you need when welding over your head.
/ new to welding #34
There is some words to live by! One time I was welding side by side with a guy, we were both running 3/32 inch flux core around the 500-amp range. We stood up a sheet of plywood between us. Every once in a while I noticed some light from his side of the plywood but didn't really think to much about it. By the end of shift my right eye was bothering me a little, just figured it was some grinding dust in it. About 2:00 A.M. I couldn't take it anymore, off to the emergency room for eye drops for a flash burn. About two days latter my wife could peel the hide off the right side of my face and neck.:laughing:
/ new to welding
i`m setting aside $3k for now.you mentioned helments from miller, lincoln etc. should those be the only ones to consider?
cm
/ new to welding #37
cm
I have a low model lincoln, and I love it. If I was to get another helmet, it would be either a higher model lincoln, a miller elite, a high model speedglas, and maybe one of the jacksons. Another thing that is good to have is a pair of carhart overalls, that and a welding jacket is great for everything welding and cutting. (and it keeps your clothes clean) As far as other things you will need, atleast one grinder, I have 3 and I wish I had one more. I would recomend either makita, milwaukee, dewalt, or metabo. 4.5 inch and 5 inch are the ones I use the most. A 7 inch is nice to have, but you can go without it. (until you discover how nice they are) I got my 7 inch for $45 at a pawn shop, and it is one of the best ones. For torches, get a good one. I have a relabled cocona, a very good torch, but the airco style tips arnt that cheap. If I was buying a torch again, I would get either a smith or a purox. They both have a lifetime warranty (unlike most others), and I like my little smith more then my cocona. The purox also has a lifetime warranty for the regs as well, so that is probably what I would get. Another thing that is nice to have is a porta band, I have a 60 year old porter-cable that I got on ebay cheap, and it will last forever. I would say either a used milwaukee or worm drive porter-cable. This post has gone on long enough, so I think I will end it here.
/ new to welding #38
cm
Candyman, if I was you, I'd get a good helmet, cotton flame proof jacket, skull cap and good pair of safety glasses.. Being on the farm you should already have a pair a leather gloves & maybe coverall's. Practice welding with the new welder on scrap metal for awhile. Then start adding to your collection of welding stuff. As for an A/O outfit Victor or Harris Heavy Duty. Burning/cutting metal is not hard, but a whole lot more hot & heavy sparks. When you start to smell rags burning while cutting or welding, check your pants legs. As for shoes, a pair of leather boots, something you can get your foot out of real fast when cutting with a torch, when welding or cutting the sparks sometimes will get in pass the tongue of the shoe. Nothing like digging slag out of the top of your feet or the heels.
Cotton is your friend, it will burn but not melt into the skin like nylon and some of the other man made materials.
So grab a 5lb box of rods, a helmet & dig out an old pair of jeans, a heavy cotton shirt or jacket and burn some rods with the new welder.:thumbsup:
/ new to welding #39
i will be running the welder mostly on a generator, which has been shipped ,be here wednesday.
I've read about generators and electronics and sine waves and square waves and awful things happening if you don't have the right one.
Is this one of those expensive lessons if he fires up his new welder on your typical generator????
/ new to welding #40
I believe he is getting the one we discussed over the phone. This generator has been used by at least a couple of our customers with this particular unit. They are clean power, and fairly inexpensive. Lets just say, he couldn't buy a used, worn out Wildcat for what Candy will have in a separate generator and 200 amp inverter welder.
2019 CATERPILLAR 259D SKID STEER (A65056)
2019 CATERPILLAR...
John Deere 5320 (A64911)
John Deere 5320...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
1996 International 4700 (A64127)
1996 International...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
