New To Using MIG
/ New To Using MIG #31
Brandi when you switch to Mig, I really like Lincoln's Superarc L-56 wire.
SuperArc(R) L-56(R)
That wire needs 100% CO2. I was gonna buy a bottle of 75% argon, 25% CO2.
hugs, Brandi
Brandi I run it with C-25 / 75% argon, 25% CO2.
Oh...okay. You have gave me two choices to try. So this with gas and the Hobart B21 for without gas, right?
hugs, Brandi
That's all I used in my home shop, L56 wire and C25 gas.
/ New To Using MIG
Hey Kenny. Glad you found me here. I value your input too! I checked today...........my local Lowes carries Lincoln L56 wire. Yippee.
hugs, Brandi
/ New To Using MIG
I just bought the same hobart 210 welder last week. I'm enjoying playing with it. I have a 60 cu ft bottle with c25. You will like the clean welds it makes over the Flux core wire. Much less smoke as well. Shielding gas welding is best indoors without wind. I'd leave the fan off unless you are out of the direct draft.
I love the machine as it is now. It sounds like it will be a "gas" welding with gas. Haha, I made a funny.:laughing:
hugs, Brandi
/ New To Using MIG #34
hugs, Brandi
I plan on burning a lot of wire playing this weekend. I'm still practicing but have a couple projects planned in a couple weeks after i get more practice. I went to a local shop and picked up a lot of drops to practice on .
/ New To Using MIG #35
You are far more patient than me... when I started practicing... it was on my first projects. Granted, they weren't going to hurt anyone if the welds failed. A couple of greenhouse benches/tables with wood slat tops, large flower pots stands using HF scroll/bender, a mod to my welding cart, etc. Still don't plan on building anything to run on public roads. Not yet anyways! Happy welding... sure is fun.
/ New To Using MIG
Only way my welding projects will get on the road will be attached to my Mahindra. I might weld up a timber storage rack for my 29 foot gooseneck. Will that count as on the road............or will it be above the road?
hugs, Brandi
/ New To Using MIG #38
hugs, Brandi
Don't weld anything where a failure will have a high probability of causing injury or death until you have a fair amount of experience. Anything failing on a road going trailer has a high probability of hitting other vehicles & people.
It's one thing if your lumber rack in your yard fails it might hurt you, but is generally not likely to be that dangerous. Trailers ratchet up the danger by a lot.
I have some skill & experience welding. I won't hesitate to weld on any of my tractor implements, but I won't touch a road trailer yet. The risk & cost of failure is just to great. I might be getting a busted trailer & fixing it, but after that I won't consider it road worthy, it's just going to be a tow behind tool & impliments cart for behind the tractor.
/ New To Using MIG
Key word........................"might". Did I say I was doing it? You have no idea where I would put a rack. It might be on the deck and strapped down for all you know.
Why do some people read too much into talk here and in life? Move along folks, nothing to see here. I am smart enough and have enough experience as a(n) (aircraft) mechanic and metal fabricator (39 years) to know how things fail and what caused it to fail.
Brandi
/ New To Using MIG #40
Didn't meant to offend. I've seen somebody because of a poorly built homemade trailer, so it riles me up a bit more than others. Some people think just because they can do something means they should do something. Hard to know peoples skill level, overestimation of their own skill level & tolerance of bad ideas that could hurt others from just a few paragraphs on the Internet.
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
5' MOWER (A52706)
5' MOWER (A52706)
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59906)
2008 HINO 268 4X2...
